I need help fast! H/c install had fire!
am i f'd
Is it possible an O2 wire got burned? One of the front ones I mean. The lack of an o2 sensor AND the valvetrain change (without a tune) could definetely be an issue in trying to get it to idle.
I would think checking for anything else that may have gotten burned by the fire could help out. Also, it may be worth while in clearing the trouble codes and seeing which ones come back now that the ground straps to the heads are tight.
Best of luck
you can`t throw heads and cam on and expect the car to idle like stock.
you need to bump up your idle RPM and desired airflow.
Noticed a tiny tiny drip from the rear passenger. So gonna pull the head back off and get new gaskets. I cleaned it really really good and torqued to spec in the right pattern. I dunno what happened but I'll check everything out again while i'm back there. make sure you tighten the plug on the pass side that plugs the whole where the coolant temp sensor goes on the driver side (you know since there is a whole on both heads and a sensor goes on the driver side and a plug goes on the pass. side) for the coolant leak and the coolant bypass tubes (or plugs for a LS6 intake) under the intake on the back side of the heads
