what is the best oil pump?
I ask because I was thinking of picking up the SLP double roller from a member here:
https://ls1tech.com/forums/lsx-parts...iming-set.html
I was also thinking of using the Edelbrock 2 piece timing cover:
http://www.ajusa.com/details/index/183/0/0/EDE%204254
Thanks guys!
DM
from what I just found, the 96 offer an 18% increase in volume over stock pumps vs. the 95 with only a 10% increase. I guess there is a difference between the two outside the clearance issues.
DM
Is the stock pump really inadequate? As it is I hear about issues with pumping the oil pan dry with the f-body pan in autocross situations... isn't a high volume pump just going to make that even worse? Stock LS motors seem to run forever... what makes a modified one need more oil?
Do'h...! Sorry guys... I did not realize that I zombied a thread, lol.
