What oil to use on a high mileage LS1?
Old 03-20-2008 | 06:44 AM
black01_WS6's Avatar
In the florida heat i run RP 10W40 and the ls1 likes it here.
My DD gets Rotella diesel oil yes diesel oil- has more cleaning agents, and works very well on every day drivers in hea, I wouldn't run this oil in the winter up north though as it is a bit thicker.
rotella also has a synthetic that works very well.
Old 03-20-2008 | 07:55 AM
Deeavi's Avatar
Amsoil 10w-40 or Mobil1 10w-40 - Both are good! My Z28 had 92,000 miles on it when I bought it 6 years ago. I switched to Amsoil 10w-40 mainly because Mobil did not offer that weight at that time. I have stuck with the Amsoil, but either would be fine in my opinion.
Old 03-20-2008 | 12:10 PM
Bad Blu Formula's Avatar
I run Castrol Syntec 10w-40 on my 140k motor because its a little thicker than M1. Seems to do the job and it drinks it less than with the M1.
Old 03-20-2008 | 01:12 PM
kirby's hawk's Avatar
Ok so I am wondering. This guy has 80 psi cold and 65 psi warm and i am guessing he is using 10w30. I've been using castroil syntec 10w30 in my car and i only run 60 psi cold and like 40 psi when its hot and about an average of 50psi. Is my pressure low or is his unusually high. I was planing on switching to castrol 5w40 next change. So advice on what to run would help out.
Old 03-20-2008 | 02:00 PM
COD02SS's Avatar
Mobil 1 SUCKS.
German Castrol, Amsoil, RP, Redline - All Group 4 Synthetics
Quick Reply: What oil to use on a high mileage LS1?
