Engine rebuild help part #'s
Old Mar 17, 2008 | 07:13 AM
Mustang Hat'r 2's Avatar
Default Engine rebuild help part #'s
Need a lot of part #'s or a place to get a good kit for all this.
Intake gaskets
Crossover gaskets
Water pump gaskets
Head gaskets
Valley cover gasket
Oil pan gasket
Front cover gasket
Rear main seal
The little gasket or plug that goes in the back of the block to hold the oil pressure?
Thread and pitch for head bolts, the main large ones as well as the one on the face(P/S pump)
Bell housing bolts thread and pitch(for engine stand)
Anything else add it in, I have the oil pump o-ring. Anything else inside the motor?
Jay
Old Mar 17, 2008 | 09:55 AM
Found most of them
Intake gaskets 12533587
Crossover gaskets 12551933
Water pump gaskets 12559271
Head gaskets 12558809 12558810
Valley cover gasket 12558178
Oil pan gasket 12558760
Front cover gasket 12558013
Rear main seal 12585671
Valve cover gaskets 12560696
Crank bolt 12557840
Header gasket 12558573
Front main 12585673
Spark plug wires
Thread and pitch for head bolt M-11 X 2.0
The ones on the face of the head(P/S pump)
Anything else
