Engine noise video please help
Old Mar 25, 2008 | 06:45 PM
bearcatt's Avatar
LS6 springs are fantastic not fan-tas-tic.
How long are those chromoly pushrods ?
Old Mar 26, 2008 | 03:01 AM
Rambo06's Avatar
It's possible for it to be a tensioner or idler pully so start the car with out the belt on that will soulve that. If it is the engine I would check the roller bearings in the rockers, and to check the lifters use a pushrod and push down on each one and if they push down real easy than there bad. Also don't rule out a cam bearing beacuse you have a sqeak and knock so check everything carefully.
Old Mar 26, 2008 | 03:03 AM
smokinponcho73's Avatar
the pushrods are 7.4" ill try pushing them again i tried but it felt pretty solid to me. also someone said its not good to start the car without the tranny so what is your suggestion rambo? thanks
Old Mar 27, 2008 | 02:39 PM
212's Avatar
212
my ss is making that same noise just without the squiking. I put that sea form oil treatment in the oil tank and let it sit for about thalf an hour and it quieted the knocking alot im doing a oil change tomorow checking to see if there's any metal on the drain plug that will tell me is the connecting rod is the problem.
Old Mar 27, 2008 | 03:02 PM
1994Z28Lt1's Avatar
as long as the flywheel and harmonic balancer are in place and you dont plan to bounce it off the limiter there is absolutely nothing wrong with running it without the transmission
the only real difference is that the pressure plate isn't bolted to the flywheel which isn't even a big deal its not like it balances the engine
Old Mar 27, 2008 | 06:40 PM
Cape T/A's Avatar
im going to say rod bearing
Old Mar 27, 2008 | 10:46 PM
01ssreda4's Avatar
you aint got no tranny thats the problem
Old Mar 27, 2008 | 11:09 PM
zrocket_99's Avatar
all that noise is coming from the top of the engine it sounds like to me, all i hear from underneath the car is the open headers. the knocking sound almost sounds like a rocker hitting the valve cover, or a broken valve spring. if it was a rod knocking or a spun bearing you could hear it from underneath the car. just my .02
Old Mar 28, 2008 | 07:47 AM
i have the rockers off all of the pushrods are straight and the lifters feel firm i guess the next step is to pull the heads, which i dont want to because then ill want to go with an aftermarket set heads and im wanting to save my money for a rear end.
Old Mar 28, 2008 | 09:11 PM
1BADAIR's Avatar
you have it that far down now I would just yank it out in less than a hour and pull the pan
Old Mar 29, 2008 | 10:43 PM
heads are next intake is off
Old Mar 30, 2008 | 09:31 PM
  #32
i found out the lifters are ls7 lifters
Old Mar 30, 2008 | 09:36 PM
  #33
bearcatt's Avatar
How do they look ?
Old Mar 30, 2008 | 09:40 PM
  #34
not sure yet but i found out from the guy who i bought it from
Old Mar 30, 2008 | 10:21 PM
  #35
bearcatt's Avatar
From what I've read on this forum, basically all LSX replacement are LS7.
In other words they replace the original LS1 lifters.
Old Apr 1, 2008 | 12:00 AM
  #36
99ls1bowtie's Avatar
might sound crazy, but i had an exhaust leak that sounded just like that! i thought it was valvetrain noise, then it got louder and i thought it might be a rod bearing. sounded metal to metal, and squeeked just like that. wierdest exhaust leak sound ive ever head. it turned out to be my header bolts were loose and the gasket bang and squeld back and forth like a blad of grass does between your thumbs. check that out too.....
Old Apr 1, 2008 | 01:36 AM
  #37
turned engine over with head off and the number 6 piston had alot of slop in it so i guess it is off to pulling the motor this weekend. (i usde a socket on the crank not the starter)
Old Apr 1, 2008 | 09:28 AM
  #38
bearcatt's Avatar
Damn dude, that sucks. Sounds like it might be time to build a bigger and better LS1.
Old Apr 1, 2008 | 05:40 PM
  #39
yep, but i dont know how much i can afford right now
Old Apr 1, 2008 | 05:55 PM
  #40
bearcatt's Avatar
Well maybe you can get a nice rebuilt or new short block.
How many miles are on your car, I mean many LS1s are known
to go for way over 100K+.
Unless someone was putting the hammer down.
