Oil Pump Install: How Difficult?
Old Mar 18, 2008 | 08:54 PM
Rushin's Avatar
Question Oil Pump Install: How Difficult?
Hey guys I'm having oil pressure problems.
Just to rattle down the info:
When the car warms up, the oil pressure is usually around 40 (give or take). Once I come to a complete stop, the oil pressure usually drops to right over the red. I have had it go to zero twice on me. I'm assuming it's the oil pump. Before I install it, however, I'll go ahead and change the filter to K&N (I think I put a Fram in it last time. Learn from my mistakes ) and run Mobil 1 through it. If that doesn't fix the problem, I'll partake in the great activity known as oil pump replacement.
Question is: How difficult is it to replace?
SORRY FOR THE LONG THREAD!
Thanks in advance,
Ilya.
PS: Any tips or suggestions would be helpful.
Old Mar 18, 2008 | 09:00 PM
LS698ta's Avatar
its not so difficult. ls1howto.com has a tutorial...The hardest part is putting the pickup tube in and bolting it back.
Old Mar 18, 2008 | 09:04 PM
Rushin's Avatar
Yeah so I've read... The o-ring gets pinched?
Old Mar 18, 2008 | 09:06 PM
sroach20's Avatar
all i can say is have fun. of course, it would be a great time for a bigger cam.
Old Mar 18, 2008 | 09:20 PM
Rushin's Avatar
Originally Posted by sroach20
all i can say is have fun. of course, it would be a great time for a bigger cam .
Oh don't worry...
Old Mar 18, 2008 | 10:49 PM
SOMbitch's Avatar
And timing chain, cam, YT Ultralites, UD pulley, EWP, TFS heads, F.A.S.T.90/90, STS...... wait a minute.... I'm runnin outtta money.......
Old Mar 18, 2008 | 10:54 PM
Rushin's Avatar
Pocket change!
Old Mar 18, 2008 | 11:11 PM
Dustin 98TA's Avatar
Im sorry but it really sounds like you might have more problems than the pump. Usually when you have pressure problems after it warms up, it will be a clearance problem.
How many miles are on the motor?
Old Mar 19, 2008 | 08:55 AM
BLACK2001SS's Avatar
Check the Gague and sending unit firts befor just replacing the pump just to be shure.
Old Mar 19, 2008 | 11:00 PM
Rushin's Avatar
Well relatively speaking, I have pressure problems throughout the entire temperature range... Even when cold, my pressure doesn't go over 40 anyways, unless I REALLY get on it. Miles? Heh... 207,XXX Don't worry, I've got another motor for it. I just wanna save this one for the time being. It is my DD.
*Edit*: Even though I'm having these bullshit problems, I'm still in the "safe" range of 10 psi/1000 rpm.
Old Mar 19, 2008 | 11:03 PM
TransAmcoupe98's Avatar
Could it possibly be a bearing???
Old Mar 19, 2008 | 11:04 PM
Rushin's Avatar
I'm sure I would hear a spun bearing...
Old Mar 19, 2008 | 11:53 PM
Boosted 99 TA's Avatar
its not to bad ive done it on my car and that was the first time ive done it. i also did a cam and some other upgrades, the hardest part is the bolt on the pick up tube like someone said but i got my fat *** fingers in there so im sure you can.
Old Mar 20, 2008 | 05:19 PM
badass99ss's Avatar
Loosen the oil pan bolts and let the pan hang a little. Don't remove them, just back them out. The little room this gives you helps ALOT. LS1howto.com works good for a guide.
Old Mar 20, 2008 | 05:44 PM
eallanboggs's Avatar
They're not hard to change unless you swap the OEM for a double row,but I wouldn't be so quick to blame the pump. You might get your feelings hurt if you go to all that trouble only to find you have the same pressure reading as before. I agree that you might suspect bearing clearances considering you have over 200K on the clock.
Old Mar 20, 2008 | 08:35 PM
Camaro396's Avatar
Not hard at all. The biggest bitch is doing the pickup tube bolt. It can be a pain in the dick. I dropped mine once into the pan. Pen magnents are your friend.
Old Mar 20, 2008 | 10:12 PM
Rushin's Avatar
Well the previous owner mentioned something about it being due up for a pump. I was just questioning his automotive knowledge when I drove the car, since seeing 40 psi warm seems normal to me. But then it started this **** and I'm assuming he was right. I guess we'll see!
Old Mar 21, 2008 | 09:02 PM
Im sure Rushin isnt talking about a spun bearing. Hes probably talking about clearances. If the clearances are too big it will drop the oil pressure dramatically.
Change the oil with some thicker weight oil it will have more pressure. Its not a fix, but it will get you by.
Old Mar 21, 2008 | 10:26 PM
HEMIETR's Avatar
Melling 10296 pump will help as well.
