LS1 push rods question
Old Mar 26, 2008 | 04:29 PM
josh2002-ws6's Avatar
Yeah they are reading fine. The injectors and coil packs are good also.
Old Mar 26, 2008 | 04:33 PM
bad6as's Avatar
try puting the tune back to stock?
Old Mar 26, 2008 | 04:53 PM
I have tried that also.
Old Mar 26, 2008 | 08:00 PM
aerotest's Avatar
Plug wire?
Old Mar 26, 2008 | 09:47 PM
Already replaced. Read the whole post.
Old Mar 27, 2008 | 08:35 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
I don't want to be the one who says it, but sometimes people collapse lifters on a severe over-rev as well. I'm sure there are little things that we're overlooking though. Check your compression and leakdown on all cylinders. Are you only getting p0300, or are you getting cylinder specific codes (p0301-p0308)?
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Mar 27, 2008 | 08:43 AM
slowmofo's Avatar
Originally Posted by Scoggin Dickey
I don't want to be the one who says it, but sometimes people collapse lifters on a severe over-rev as well. (p0301-p0308)?
that was my guess as well..
Is the car still making noise?
My car has some type of tapping coming form the center of the motor.. Runs fine no codes good oil pressure just has a good tick.. Sounds like a lifter, although a few friends think its a pushrod. I am about to pull the top half of my car apart to change lifters springs heads ect..
Old Mar 27, 2008 | 10:36 AM
Yes it is only a P0300 now. I have not gotten any codes for specific cylinder misfires. I am gonna do a compression test and leakdown test tonight. I will let you guys know how it goes. How do you tell it is a collapsed lifter? When I hit the rev limiter, it was pretty hard. The car dropped the RPM's to like 900 before it shifter to 2nd gear.
Old Mar 27, 2008 | 11:05 AM
slowmofo's Avatar
is it making any noise? or just throwing codes?
Old Mar 27, 2008 | 01:00 PM
It was making noise before I changed the pushrods but now I don't hear anything.
Old Mar 27, 2008 | 01:11 PM
GMmexican's Avatar
speaking of pushrods......who makes the best ones? (thunder,tsp,comp cams)
sorry to hijack your thread
Old Mar 27, 2008 | 04:03 PM
  #32
aerotest's Avatar
**** Edited ****
Warning - Play nice....
Old Mar 27, 2008 | 04:13 PM
  #33
Black Plague's Avatar
Originally Posted by aerotest
removed
Old Mar 27, 2008 | 04:16 PM
  #34
fastvet's Avatar
I have my rev limiter set at 7000 and shift at 6400. The only reaon is cuz when I spray, I am not taking any chances on hitting the rev limiter with spray. I took my heads of to do a swap yesterday, and the stock pushrods look great. So do you think it was the pushrod or the way you re-bolted the rockers that stopped that ticking?
Old Mar 27, 2008 | 06:32 PM
  #35
Cape T/A's Avatar
since it was still acting up on you after you put your new plugs in you may have fouled them out again, see how they look. you may need a few new ones.
Old Mar 27, 2008 | 08:47 PM
  #36
The plugs look good still, I check them about 3 hours ago thinking the same thing lol.
Old Mar 27, 2008 | 08:56 PM
  #37
**** Removed ***
Wow you don't have to be a jack *** like that. If you are going to make a comment or ask a question read the whole post first. Sorry to have offend you and thank you for your idea on what could have been wrong. Please delete your post.
Old Mar 28, 2008 | 05:24 PM
  #38
Bill Bowling's Avatar
Please do.
