Heads Cam And Intake Swap ......
Old Mar 22, 2008 | 09:22 PM
jryder916's Avatar
Default Heads Cam And Intake Swap ......
I Was Just Wondering If There Are Any Special Tools That Ill Need During The Swap Also Looking For Some Tips And Pointers Thanks
Old Mar 22, 2008 | 09:43 PM
COD02SS's Avatar
Have a professional do it. If you need to ask this you're not skilled enough to do it.
http://www.ls1howto.com/index.php?article=23
Old Mar 22, 2008 | 10:09 PM
Grimes's Avatar
no super special tools. You may want to get a tool someone sells here to reinstall the pulley - it's made of a piece of threaded rod so you don't have to use the stock pulley bolt to pull the crank pulley back on
Same thing goes for compressing the springs - Crane makes a nice tool that allows you to change two springs at the same time.
only other thing I can think of is a set of gear wrenches to get hard to reach spots.
Old Mar 22, 2008 | 10:16 PM
prochargedchevyi's Avatar
The cam is a super easy job - just a 360* twist to raise the lifters, then replace it with the new stick. You'll need a degreeing wheel. My Moroso DW cost me $40.00.
Intake, again, a very simple job.
If you don't know how to assemble heads, I'd probably let a professional do it.
The best thing I can recommend is getting a manual and reading it over a few times to gain some confidence. Make sure you're NOT reusing the same heads bolts, use the moly lube, and follow the torqueing procedure to a 'T'.
Other than assembling the heads and degreeing the cam, it's a pretty straightforward engine to work on.
