90mm maf?
does anyone have any experience using this maf?
does any tuning need to be done in order to use it?
i think that is a pretty good price considering they probabably dont mass produce them by the tens of thousands.
cause the tuner screwed it up i was gonna run sd but now i need a maf to break the car in and getting running and im probably going to use a different tuner now.
If you do some searches, you will find that people are seeing impressive gains when using a large MAF meter.
The 6.0 85mm is the same as 01-04 Z06 which is the same as most 01-05 LS MAFs which is all different than the 06-08 and different than the 100mm PowrMAF. The new sensor is made for GM by Hitachi and is light years from the open wire early style. While your PCM may not be able to use the full range, it is ~4x the previous and far less restrictive.
