Had cam doctored, need help deciphering printout
Old Jul 6, 2012 | 08:46 AM
quik95lt1's Avatar
Originally Posted by bigantws6
I have Cnc ported heads and I beam rods but running stock crank will I be alright reving it to 6500 so if tuned at idle around 1000 will it be okay or will it still surge
would need flow data on heads to make a good call on the cam.........what I beam rods? the crank isn't an issue long as its balanced well.......i rev bone stock ones higher than that so i wouldn't be afraid of 6500 but i see that going much higher than 6500 lol.......the idle you could probably get steady around 1000 if you are a good experienced tuner....but light pedeal buck under 1600-1800 will most likely be rearing its ugly head regardless of tune.....
Old Jul 6, 2012 | 09:23 AM
bigantws6's Avatar
Manley I beam rods are the ones I have and what is this buck thing sorry .......so this cam will not benifit me me at all
Old Jul 6, 2012 | 09:31 AM
bigantws6's Avatar
With a good tune can buck get eliminated
Old Jul 6, 2012 | 11:55 AM
wildcamaro's Avatar
It will try to push through the brakes you will have to stand on them at stoplights
Old Jul 6, 2012 | 12:25 PM
bigantws6's Avatar
Even with a 4000 stall if so dam
Old Jul 11, 2012 | 09:40 AM
quik95lt1's Avatar
no it wont espically with that stall.....i ran a 4200 converter on the street with a 1300rpm idle with no issues and that was with manual brakes plus the in gear idle should be able to be dropped a bit to stop the car from trying to target too high and idle.....
