Had cam doctored, need help deciphering printout
Old Apr 1, 2008 | 03:10 PM
Gregg 00SS's Avatar
Default Had cam doctored, need help deciphering printout
Had my cam doctored and got it back today with a printout with a hell of a lot more info than I really needed, lol. Curious if someone could help me figure out exactly what I have.
Old Apr 1, 2008 | 03:16 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Post a scan of the report.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Apr 1, 2008 | 04:00 PM
Gregg 00SS's Avatar
Here ya go.
Attached Thumbnails Had cam doctored, need help deciphering printout-camdr.jpg
Old Apr 1, 2008 | 04:12 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
248/247 .593 lift ~111LSA
Old Apr 1, 2008 | 04:15 PM
Gregg 00SS's Avatar
Would it be safe to say it is NOT a T-rex, which it was claimed to be when I purchased it. T-rex specs are 242/248 - .608/.612 - 110 lsa
I know each individual cam differs a little in it's exact specs, not sure what that margin is though.
Old Apr 1, 2008 | 04:18 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
cams are not always perfect, they may be a little larger or a little smaller than advertised based on what COMP, CRANE, ETC claim as acceptable through there QC process.
Old Apr 1, 2008 | 04:55 PM
slmdLS1's Avatar
+1
who'd you buy it from?
Old Apr 1, 2008 | 05:00 PM
Gregg 00SS's Avatar
A member on here. Not gonna run his name through the mud because once I expressed my concerns about it, thus me getting it doctored, he was more than willing to refund my money if it ended up not being a T-rex. He was 100% positive it was though, so not sure what the deal is.
Old Apr 1, 2008 | 05:56 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
there should be numbers scribed into the front of the cam, post a picture or what they are and we can tell you what lobes they are suppose to be.
it could very well be a t-rex and it falls with in the QC tolerances.
Old Apr 1, 2008 | 06:39 PM
Gregg 00SS's Avatar
Has 251031 stamped on one end and 0118061 etched on the other
Old Apr 1, 2008 | 07:17 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
no individual nubers like 1235HR 1356TK 110LSA????
Does anyone know if thunder uses Comp/crane/cam motion?
You can always call thunder to see if they can help you out.
Old Apr 1, 2008 | 07:27 PM
405HP_Z06's Avatar
The lobes don't match any of the Comp or Crane profiles. Interesting to find out what this is.
Old Apr 1, 2008 | 07:39 PM
hammertime's Avatar
+ 1
If the Intake Lobe Centerline is 109 and the Exhaust Lobe Centerline is 111, isn't this cam ground on 110 LSA with one degree of advance? I know, I know it's one degree.
IMO, 6 degrees larger than the advertised intake lobe, while falling .015n-.020 short on lift doesn't seem like the same cam.
Old Jul 6, 2012 | 12:06 AM
wildcamaro's Avatar
That is a wild split...I would say solid roller but the lift isn't high enough
Old Jul 6, 2012 | 06:18 AM
bigantws6's Avatar
This guy trading me this same cam dam this is a old post how do u think this cam will work in 346
Old Jul 6, 2012 | 08:15 AM
Gunslinger09's Avatar
Great at WOT. It will be hard to live with on the street even with a tune.
Old Jul 6, 2012 | 08:22 AM
bigantws6's Avatar
Y is that
Old Jul 6, 2012 | 08:23 AM
quik95lt1's Avatar
248/247 .593/.593 110.4+1 LSA
without a good head on the car i wouldn't run it and expect to see 7krpm
in a stock cube ls1 id expect a 1000rpm idle with not so hot street manners under 1600-1800 or so even with a good tune i just tuned a 249/253 112lsa in a 403lsx and it idles 1000 and is choppy under 1500 or so....ur in his range but 50+cubes short so your gonna know that cam is in there........may even want to rev beyond what a stock shortblock can handle
Old Jul 6, 2012 | 08:28 AM
Y is that
Because it has so much duration and overlap the motor will not pull much vacuum. At low RPM idle it will buck and surge and try to stall.
Old Jul 6, 2012 | 08:42 AM
bigantws6's Avatar
I have Cnc ported heads and I beam rods but running stock crank will I be alright reving it to 6500 so if tuned at idle around 1000 will it be okay or will it still surge
