383ci making 340whp - advices needed
Dumb Ass Vette Moderator
That is the band fix. If you want to increase the compression ratio without changing the pistons, switch to a set of 5.3L heads. Their combustion chambers are 58cc and you can have them milled down all the way to 53cc. If you want to lower the compression level later on, put th eoriginal heads back on.
Keith
Keith
^^^ I agree with the above statement. Those heads can be had pretty cheap and you can mill them down. Also look for a cam 232-238/236-242 with a low .6xx lift and 112lsa
That should up your compression and give you some good power.
you may have to pull a couple of the studs out,that makes it alittle easier.a 59 cc chamber would really help but if you don't want to pull the heads you will have to make a compromise.
what does your complete exhaust setup consist of,long tubes and a good ory ?
maybe go with a cam like a 232/236 on comp xer lobes or xfi of similar duration on a 110 +2 or so to try to keep the dcr as high as possible to keep from killing your torque. hit up predator-z or patrickg on here and they should steer you in the right direction.
#33
Just looked in sales section and looks like heads will cost me well over $1000, plus shipping, taxes and so on... Not worth it.
So that leaves me with just cam and maybe better intake, I guess...
slow trap, exhaust is:
Pacesetter LTs
Pacesetter ORY
Flowmaster 3" catback
I'll do the work myself, cause no one tunes american V8s here. I'm the first![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
And I'll deffo tune it myself - being an IT person, I like it
Pacesetter LTs
Pacesetter ORY
#36
I say wait for the turbo. Get the nitrous setup PROPERLY, and when you are itching for some excitement, spray it. I think that will be your best solution until you can afford the turbo, since you said it already has nitrous just not set up. Minimal cost, maximum fun.
#40
Cam is hurting you, especially for a 383. Also, you need comression. If you can cut the chambers down to 60cc, you'd be in better shape. But that won't run well with a turbo.
Here's the problem: the motor was built for a turbo. Without it, expect much lower performance. No way around the parts needed for a turbo compared to a naturally aspirated motor. Two totally different requirements.
But, you knew this already......
You could just throw some spray on it for now..
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
