cam?
Old Jul 28, 2003 | 11:13 PM
Jeff24SS's Avatar
Default cam?
I have ordered mti stage II heads with the b1 cam. I am thinking the b1 is to mild. My car is a 01 ss, added in case it doesn't show at bottom of post, with CME, SLP LT headers w/ high flow cats and y pipe, CAI, MAF, LID, bellows, PHB, LCA, STB, SFC. I don't have emissions testing and loudness isn't a major concern. I think the 114 lsa in a c2 or x1 would be good unless their wouldn't be problems with going with the 112. Their is a speed shop I can have it dyno tuned on, but it is the mustang dyno. Others dynos further away I could go to though. Appreciate any suggestions you may have. Thanks.
Old Jul 28, 2003 | 11:42 PM
someday's Avatar
Default Re: cam?
u DIDN'T say what trans u have... if ur an A4, the B1 would be fine... it also depends on how smooth u like the idle... C1 on 112 will keep ur peak down to a reasonable level, but be less smooth... X1 would be good on an M6, but would be rougher and peak higher...
Old Jul 28, 2003 | 11:45 PM
Jeff24SS's Avatar
Default Re: cam?
have an a4, try to put as much info in and always leave something out.
Old Jul 29, 2003 | 01:33 PM
Constrictor 98TA's Avatar
Default Re: cam?
If you dont care about emissions and you dont care about loudness or lope, then you can go as large as you want. I went with the cam in my sig and I have an A4 as well and I absolutely love it. As long as you get tuning, almost any cam will work regardless of the LSA.
Old Jul 30, 2003 | 07:04 PM
99 Black Bird T/A's Avatar
Default Re: cam?
With MTI heads having the dual springs I'd go with the C2 over the C1 or B1. My cam is similar to a C2 at 224/224 .581, I think C1 & C2 both have the edge over the B1
