Advice on Cams!
Old Apr 7, 2008 | 04:23 PM
Moscosoalfredo's Avatar
Default Advice on Cams!
I would like to get some cams....I WANT A DAILY DRIVER CAM!!!!!! I DONT WANT A MONSTOROUS CAM! I am not looking for a huge gain i just want to have get to the 12's with out getting a stall or rear gears.......well i was on craigslist and i found someone with this.....if you have any opinions on what i should be looking for just tell me..... I dont want a required tune cam.... you know.... i will tune my car.... but i dont want to have to do it right after!
Grind Number# HR-287-CSB
Valve Setting:
IN./Hyd.
EX./Hyd.
RPM Operating Range:
1800 to 6600
Duration:
Advertised IN./.287 EX./.287
@.050" IN./224 EX./224
Valve Lift:
1.7 Rocker: IN./.545 EX./.545
Springs: LS1
Lobe Sep. Angle:
114
Old Apr 7, 2008 | 04:28 PM
JS's Avatar
JS
I would run something like a TR220 cam...I would try to convince u to go converter,a 2800 is like stock an with the TR220 it would work great
Old Apr 7, 2008 | 04:35 PM
ok ok.... thanks for the advice
Old Apr 7, 2008 | 04:36 PM
What about this one
http://www.lmperformance.com/4185/1.html
Old Apr 7, 2008 | 04:47 PM
CAMAROZ28AQUINO's Avatar
id go like 216/220 with good amount of lift with a small stall
Old Apr 7, 2008 | 04:49 PM
Camaro396's Avatar
You want to get some cams? Buy a honda. If you want A cam, then your good to go with what you have
Id look into a 224 or so. They are a good DD cam. The only thing is your going to want a stall with whatever cam you go with.
Old Apr 7, 2008 | 04:53 PM
Dragkid1917's Avatar
haha i do that to my frends all the time when they talk to me about "cams". Im like, Cam, theres only on CAM.
Old Apr 7, 2008 | 05:12 PM
well is like like me correcting what you said above.... you said theres only on cam.... when you meant one....i just didnt check...so yea w/e
Old Apr 7, 2008 | 05:39 PM
davered00ss's Avatar
Moderator
Stall & gears are a must. But for a great DD cam, look at the TR224. Without knowing who spec'ed out the cam on craigslist, I would avoid it.
Old Apr 7, 2008 | 06:30 PM
kingsey's Avatar
Get the Texas speed 224R its better then the TR version
