cam sensor problem code 343, need help asap
swap the polarity on the outside wires (1 and 3) on the cam position extension harness.
the cave man way would be to cut the wires/resplice.
i didn't want to booger up the wiring harness, so i took a small pick/screwdriver and popped out the pins and replaced it.
