When to switch to synthetic oil
Old Apr 7, 2008 | 08:00 PM
1BDBOTI's Avatar
Default When to switch to synthetic oil
I just rebuilt my LS1, FAST 90/90, FAST fuel rails with FAST injectors, MS4 cam, all new oil pump, rings bearings, but i just changed my oil at 200 miles... I put reg Penz back in it but I was wondering when it will be safe to change over to Synthetic motor oil???? I want to give my rings enough time to seat and my motor to break in properly......
Old Apr 7, 2008 | 08:11 PM
jlrz28's Avatar
10 Second Fun Car
Asap!
Old Apr 7, 2008 | 09:17 PM
2001 Pewter WS6's Avatar
Restricted User
1,000 miles.
Old Apr 8, 2008 | 12:47 PM
N4cer's Avatar
I'm sure you'll be fine at about any time, but I'm waiting until about 3000-5000 miles. I think that as long as you keep fresh oil in it, dino oil is fine. And even 5k miles isn't a lot of wear on an engine.
Old Apr 8, 2008 | 12:57 PM
Jeff@TotalPerformanceEng's Avatar
You are incorrect!!
The best thing to do, is to speak with your engine builder and verify what rings you are running. As well as get their reccomendations. Some rings take significantly longer than others to break in.
The point in time you put in synthetic, is the point where your rings will no longer seat. Running conventional oi doesnt hurt anything at all in the short term. Yes, it causes a few HP, but all in all, it doesnt do anything other than save you money.
I ALWAYS wait around 2000 miles prior to switching. Alot of tuners will tell you to wait longer. But it also depends on how you broke the motor in over the first few hundred miles.
Originally Posted by jlrz28
Asap!
Old Apr 8, 2008 | 12:59 PM
Kingc8r's Avatar
Good info in here and I would do as others have said, contact the builder
Old Apr 8, 2008 | 07:49 PM
1BDBOTI's Avatar
I built the motor myself.... I own a machine shop.....
Old Apr 8, 2008 | 08:06 PM
GuitsBoy's Avatar
In which case you should give yourself a call and find out.
What rings did you use? What hone? Did you leave a rough hone or did you do a finishing hone pass? If so, the plateau hone will closely resemble a broken cylinder and youll have the most compression youll ever have right out of the box. If you did a finish / plateau hone, you can switch right away.
Old Apr 8, 2008 | 09:45 PM
neals98's Avatar
This may be a dumb Q but does everyone run Synthetic motor oil in there ls1's If someone has one that does not run it should they change ?
Old Apr 8, 2008 | 09:54 PM
EastTnZ28's Avatar
I don't. Im sure I will be lynched on here for using dyno oil.
Old Apr 8, 2008 | 10:36 PM
N4cer's Avatar
It's "dino" oil. As in dinosaur. Not dyno as in dynomometer.
And nobody will lynch ya. You are just fine with dino oil.
Old Apr 9, 2008 | 04:20 PM
EastTnZ28's Avatar
Thanks for clearing that up. I've been practicing my letters.
Old Apr 9, 2008 | 04:36 PM
robertbartsch's Avatar
Mobil sued Penz for marketing a dino oil as fully synthetic a few years ago and, unfortunately, LOST in court.
As a result, everyone can now market dino oil and call it synthetic. So most do, including Mobil. Yeh, Mobil 1 is no longer synthetic.
Consequently, I would not worry too much about oil types and their marketing hype since 98% of the stuff is dino anyway. You can thank Penz for this.
Old Apr 9, 2008 | 04:54 PM
Davy_Baby9's Avatar
Except for RP, Redline, and German Castrol etc..
Old Apr 9, 2008 | 05:15 PM
JDM74's Avatar
I don't use synthetic. I use Valvoline VV851 race oil because it has the proper addatives for a forged engine (zinc and phospherus). These addatives have been taken out of street legal oils. They are also the addatives that all the old school flat tappet cam guys were complaining about when they took it out.
Old Apr 9, 2008 | 08:00 PM
1BDBOTI's Avatar
so when should i change????? I used sealed power rings it was a smooth hone finish
Old Apr 9, 2008 | 08:03 PM
GuitsBoy's Avatar
Smooth meaning rough hone first then a fine hone to plateau the cross hatching? Then switch ASAP. Your cylinders and rings are essentially pre-broken in. This is why theres rarely a manufacturer that suggests a break in period or short first oil change interval any more.
