car is acting up....
Old Apr 7, 2008 | 11:34 PM
2000NavyZ's Avatar
Default car is acting up....
so i did my cam swap this last weekend and the car doesnt always start. It cranks but wont start. i could go crank on it for 5 seconds and get nothing, go back 2 minutes later and it fires right up. it didnt have spark or injector pulse...we scaned it and ran all the possible codes through identifix and it came up as a bad ignition relay. has anyone else had this problem??? we swaped out one of the fan relays (cause its the same) and it started right up. i sure hope that was the problem, you guys got any other ideas???
Old Apr 8, 2008 | 12:27 AM
1320 killer's Avatar
There are 3 ground wires that are grounded to the back of the driver side head. It is common to forget one of the three. i would check that and also check your coil connectors to make sure they are plugged in.
Old Apr 8, 2008 | 08:31 PM
2000NavyZ's Avatar
i never had the heads off, so i dont think thats an issue
