oil pan drop
Old Apr 9, 2008 | 09:24 PM
LS1Z28_98's Avatar
Default oil pan drop
I hate to bother everyone again.... still in the cam/spring swap. I am trying to lower the oil pan to change the oil pump. There are 2 bolts under the K member. I can get them off easy enough, but I understand when it comes back to re torquing them, I have heard those will not hesitate to break if over torqued. How does one properly torque those little bastards under the K?
Old Apr 9, 2008 | 10:14 PM
Apollo0526's Avatar
I torqued the others, then took the open end and felt how much pressure there was on the bolts and tried to match it the best i could. Doesn't leak and they aren't stripped
Old Apr 10, 2008 | 01:37 AM
aaron653's Avatar
i used an open end wrench...doesn't leak
Old Apr 10, 2008 | 03:24 AM
DaddySS's Avatar
That's a good approach, just remember err on the side of caution, you can always climb under a tighten them a bit, but you sure don't want to strip them!
Old Apr 10, 2008 | 05:49 AM
Mikes96z's Avatar
Use a German torque wrench.........Goodentite
Old Apr 10, 2008 | 11:07 AM
Cap'n Pete's Avatar
I read somewhere else that the torque spec is 18 lbs on all the bolts except the rear (long) two? Apparently they take LESS torque than the rest (less than 18 ft-lbs, but I didn't get a number).
Anyone confirm this?
Old Apr 10, 2008 | 12:25 PM
bczee's Avatar
yes. the M8 ones are 18 ft/lbs, the M6 ones are 106 in / lbs. be carefull on those..
