How to check if all 8 cylinders are firing
Old 04-11-2008, 12:47 AM
Tri5Nerd's Avatar
Default How to check if all 8 cylinders are firing
I've been reading a lot lately where folks say that a engine could be running on 7 cylinders, and to check if all cylinders are firing.
Pardon my lack of knowledge here but just how do you check that?
I think checking the plug wires is one part, what else needs to be done to manually check?
Old 04-11-2008, 12:50 AM
drz
drz's Avatar
It's pretty easy, really. While the engine is running, pull injector clips one at a time and listen to see if the engine starts running differently. when you pull one and the engine is unaffected, you've found the cylinder that's not firing.
Old 04-11-2008, 12:56 AM
Z28LS1camaroguy's Avatar
you can also pull a plug wire and turn it over and see if it sparks.
Old 04-11-2008, 12:57 AM
drz
drz's Avatar
I've seen a few occasions where an engine has sat for a while (like when waiting on parts, or a new short/long block), and when it's finally fired up again, one or more of the injectors is stuck closed from having sat a while. Pulling the clips as outlined above will isolate the stuck injector(s), and a soft tap with a hand tool is all it took to free them up. Big cams with a lot of lope can mask a non-firing cylinder, especially when newly installed and the owner/operator isn't familiar with the engine's good-running sound.
Old 04-11-2008, 01:02 AM
Tri5Nerd's Avatar
So, most times the cause is that a injector(s) is closed or there are no spark from the wire?
Is there any other manfunction that could cause this probelm?
Old 04-11-2008, 01:05 AM
drz
drz's Avatar
broken parts such as:
bent valves
broken rocker arms
melted/perforated pistons (too much juice, yo!)
blown head gasket
etc.
Quick Reply: How to check if all 8 cylinders are firing
