Re-Ring for Track Car - Questions
What is the appropriate ring gap for stock rings on an LS1 car that will see roadracing type temps/use?
Also, can the pin be replaced to change a piston at home, or does it require a machine shop to do the work? I couldn't quite tell looking at it and wanted to set up a weekend appt if it needed a pro to do the work.
Thanks In Advance!
Thanks In Advance!
