TFS Stage 3 cam or Vengeance?
Looking at the VRX5 or the TFS Stg 3 Car will have TFS CNC 215's
Also has long tubes and a will have a 4200 stall. with a 3.73
Planning on running nitrous 150-200hp
VRX5- 236/238 .601/.605 113 LSA.
TFS3- 228/230 .585/.585 112 LSA
Or possibly a Patrick G custom grind in this range
Thanks
Josh
Thanks
Josh
1 Post
Have you considered a custom cam from LG Motorsports? The g5x2, x3 version I or II would also be well proven options.
I'd also say you can't go wrong by picking either of your other options. All are good choices and I don't think you'll be upset with any of the choices. Just threw LGM in there because they have EXCELLENT stuff too. Call them up, number is in my sig. Bobby or Anthony can help you out and hook you up. Good luck on what ever you decide to get.
It all depends on what you're hoping to accomplish with the cam. I have the TFS cam mentioned above as I wanted reliable street manners and good power under the curve....it succeeds at delivering that and then some.
That being said, if you're on a quest for raw power the Vengeance cam is the way to go. In hind sight for me, I probably would've went a little more aggressive (VRX4 or VRX5) as I'm now planning to upgrade heads, intake, etc.
Ron and the guys at Vengeance are well regarded for quality products and top-notch service, so I'd feel comfortable with pretty much any thing I bought from them.
