Torquer V3 Question
Old Apr 11, 2008 | 05:21 PM
z06 hellcat's Avatar
Default Torquer V3 Question
TSP TORQUER V3 DRIVABILITY ?, 04 Z VARARAM,DYNATECH LTS,CATS,X-PIPE, TORQUER 3 CAM!
WHAT KINDA POWER SHOULD IT MAKE AFTER DYNO TUNE?
HOW IS LOW END DRIVABILITY, ISSUES GOOD OR BAD, THANKS!
Old Apr 12, 2008 | 03:53 AM
PREDATOR-Z's Avatar
With a good tuner, no issues, good cam, get the right springs, at least 7.425 pushrods.
That is + bolt ons of course
Old Apr 12, 2008 | 08:57 AM
Fratsit's Avatar
I ran that cam for 2 years.
Drove fine with a tune. Had a little low rpm surging but nothing unmanagable. Started and found an idle just fine even without a tune. I will caution against slapping the loud peddle without a tune, though. First pull to estalish a baseline on the dyno and my LTFT's were WAY positive.....as expected.
Springs are a must (which you will get with the package). I would ask TSP to hold off on sending pushrods until you can measure....if you are going with the package.
With stock 853 heads and the "crappy" LS1 intake I made 385 HP at 5700 rpms. Torque was above 370 ft lbs and did not drop off below 350 until around 5700 rpms. I never got any track times to back those numbers up, though. My graph is buried deep in the dyno section. Do a search for my user name.
The tune was not the best, though....and no...the shop that did it IS NOT a sponsor.
A word of caution.... definately pay attention to your rev limiter. I bounced it 2 times and when I did the head swap I noticed I had eye lashed number 1 and 5 pistons on the intake side. I still flycut when I did my head swap even though I switched to a smaller cam.
Good luck on your decision.
How are things in Norman...my mom used to live there.
R/
Frat
Old Apr 12, 2008 | 09:45 AM
BREWS02WS6's Avatar
I've got it cam only w/ a mail tune from TSP. Its running a little rich, but thats fine until I get the full dyno tune. Actually had the mail tune for almost 2 years now also, since day 1 of the cam being in there. Like Frat said, a little surging/bucking at low rpm's but nothing to whine about. W/ stock gears it took just a couple seconds to start really moving, but w/ the 4:10s...yikes. Most people are seeing 400 after the dyno tune, sometimes well over 400 w/ the right supporting mods. Great cam though, Im glad I chose it!
