White Smoke
Old Apr 17, 2008 | 08:24 PM
StreetLethal01's Avatar
Default White Smoke
Car started smoking recently. No overheating. I can't tell if its white or bluish white. Smells like gas not really sweet. car runs fine no loss of power.
smokes more when sitting for a while.
Does this look white or bluish white?
http://s58.photobucket.com/albums/g2...rent=004-1.flv
Old Apr 17, 2008 | 09:33 PM
LS184's Avatar
trans fluid burns white, but i doubt tht is ur problem...when my ws6 is not warmed up it someties does the same thing, but i think it does tht bc its running to rich....i could use a tune!
Old Apr 17, 2008 | 10:07 PM
XtraCajunSS's Avatar
Looks like over rich condition causing oil to wash past the rings...
You may need a tune.
Shane
Old Apr 18, 2008 | 11:08 AM
Could my plugs be to cold? TR6s gapped @ 32? I recently had a tune.
Old Apr 18, 2008 | 02:36 PM
bluehawk2's Avatar
How cold is it where you are? My car does something similar to that, but only when it is cool outside(40 degrees) It only does it when you first crack it up in the morning. It does run rich for a couple of minutes in the morning and then it goes to 14.7 like normal. I think I need to work on my cold start tuning.
Old Apr 18, 2008 | 02:38 PM
00transamnh's Avatar
i think you are prolly just burnin a little erl at start up
Old Apr 18, 2008 | 04:46 PM
The video was taken in the afternoon. Temp was aprox 70 degrees. I have the car tuned for nitrous. a/f was close to 11.7 throughout the rpm range.
Does the smoke look white or blueish white to your guys?
Old Apr 18, 2008 | 04:48 PM
SO you think the valves are passing oil or the rings?
Old Apr 20, 2008 | 08:53 PM
The smoking has stopped. I think it was just bad gas. I did regap my plugs to 35 anyways.
