383 vs 408
Old Apr 18, 2008 | 12:14 PM
72RATCAMARO's Avatar
Default 383 vs 408
Whats the major difference in these stroker kits. The price will be the same with an Eagle kit so which should i go with? I drive the truck everysingle day and need it to not overheat or be unreliable. Any opinions? What if i just forged the 347. I am after maximum bang for the buck with good drivablility. Thanks
Old Apr 19, 2008 | 03:29 AM
venom ws7's Avatar
What is your Stock engine in the truck???
If your stock engine is 6.0 I say go with 408ci you cant go wrong with more CI
Heating never been a problem even here (overseas very hot) with good H/C the car
should be 450rwhp+ with A4.
Old Apr 19, 2008 | 04:55 AM
99blancoSS's Avatar
Neither, if built properly and tuned correctly, are un-reliable.
Its a matter of money really. No need for any engine to over heat if properly cooled.
Bang for the buck is hard to say, it's really tied to your budget.
Peronally I dont think you can beat a 408 these days for bang for the buck and driveabilty. I'm biased, of course, but I chose the 408 for a reason.
Re-building your 347 isnt a bad way to go, you wont have the power levels of a 408 but most likely not the cost either. A medium tempered 408 is an upper performing 347 as far as power goes. Not replacement for displacement.
Old Apr 19, 2008 | 03:52 PM
DONAIMIAN's Avatar
If you have trhe Al block then go 383, if Fe then go 408. Both motors will make close to the same power if everything is in harmony, but the 383 will be a decent amount lighter (less weight is worth more to me than others)
