Stock internals
Old Aug 1, 2003 | 10:10 PM
Kens_02SS's Avatar
Default Stock internals
Could my stock internals handle S2 heads and that G5X2 Cam.Meaning pistons and rods, i know i need a double timing chain and a ls6 oil pump but i want to make sure my pistons and conecting rods will be ok. I've got an 02 SS M6.
Thanks,
Kenny
Old Aug 2, 2003 | 04:06 AM
NataSS Inc's Avatar
Default Re: Stock internals
No, you will have to fly cut your pistons to get the cam and heads to even work right. The G5X2 is a huge cam. Even with NON milled heads it requires fly cutting the pistons.
Old Aug 2, 2003 | 05:12 PM
Kens_02SS's Avatar
Any other ideas to make this work? I want the cam so how far will the heads need to be milled?
Old Aug 2, 2003 | 08:50 PM
rich's Avatar
I think you missed the point. with non milled heads you are going to have piston to valve interference problems and with those milled heads there will be even more interference. the only way it will work is with fly cutting the pistons or getting a set of pistons with valve relieves in them already.
Old Aug 3, 2003 | 11:59 AM
B18B1LS1's Avatar
Are you guys sure about flycutting the pistons? I might be wrong but I thought with non-milled heads it would be close but still work just fine.
Jeffrey
Old Aug 3, 2003 | 01:43 PM
Z-Rated's Avatar
Jeffrey
Thats whay I was thinking, that its really really close... but it fits.
