Idle Climbs While Cars Rolling
My 99 TA 6 speed was all stock and got some water sucked up into the intake. Bent a rod, but still ran. It would idle really high, like 1200-1500. I replaced the long block, but it still wants to idle high at around 1200. Sometimes it will idle at 1500 and if I stop hard it will sometimes idle at 2000 for a few seconds. It's just all over the place. I closed off the idle hole a little and this helped drop it to around 1000, but it's still erratic.
(Covering the hole completly makes it want to surge and die)
Could the water have damaged the MAF or maybe the MAP sensor?
Could the water have warped my intake?
I don't know how to clean the tps sensor and iac sensor. Do you think the water effected them? If there is a write up on cleaning them, I could probably do it.
I'm thinking the water splashing in probably dislodged a chunk that kept it from closing properly. Anyway, thanks for the advice. It was much simpler to do than I thought.
