MS4 Supporting Valvetrain question
Old Apr 21, 2008 | 09:57 AM
JUSTONY's Avatar
Default MS4 Supporting Valvetrain question
Ok, so after hours of research, pouring over dynosheets, and watching about 439 videos I have decided to go with the Magic Stick 4 Cam. Right now I have SLP intake, no cats, Pacesetter LT's, SLP y pipe, and SLP LM. Within the next couple months I hope to have a FAST 90/90 and within the next years I should have a new set of heads. My question, is there a kit of all the supporting drivetrain components that I need to support the MS4?? If so what is the best one available for the price??? I have been looking through the threads and I havnt seen any.
PS. I am going to be putting a LS2 timing chain on while I am at it
Old Apr 21, 2008 | 10:02 AM
00cls1camaross's Avatar
you will need springs, pushrods, and Ti retainers. Texas-speed has this kit for sale
Old Apr 21, 2008 | 10:16 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
http://www.texas-speed.com/shop/item...d=175&catid=49
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Apr 21, 2008 | 11:40 AM
JUSTONY's Avatar
Wow, that made things easy, THANKS
Another question, after the install is it safe to carefull drive it a couple miles to the shop to get it tuned, or does it need to be trailered???
Old Apr 21, 2008 | 11:42 AM
bjamick's Avatar
Yep I bought the kit from TSP as well.. Now im changing cams and selling my MS4 for a custom specd cam for me.. You will definitely need to upgrade the valvetrain for that cam though. Also think about getting a ported and shimmed LS6 oil pump while your at it. ..
Old Apr 21, 2008 | 11:49 AM
JUSTONY's Avatar
Now what will the ported and shimmed oil pump do for me?? Is it needed to run the cam, or will it just make it perform better???
Old Apr 21, 2008 | 12:00 PM
Phantom's Avatar
so the 7.400 p.r. are ok with the ms4? assuming the heads aren't milled. why the ti-retainers?
Old Apr 21, 2008 | 12:09 PM
rocksws6's Avatar
You will be fine driving it to get it tuned. Just don't beat on it. Cruising won't hurt it.
The stock oil pump can go bad without warning and if this happens and your at high RPM's or you don't notice it in time its gonna cost you a new motor.
There seems to be a bunch of different recommendations on PR length. I'm running the 7.425's myself. See what TSP recommends and go with that. The Ti-retainers are part of the PRC spring kit. That's about the only way to go as far as springs if you ask me. Patriot springs are the same thing so they are good too.
Old Apr 21, 2008 | 05:29 PM
JUSTONY's Avatar
I've also seen that most people go with the LS2 timing chain. Is this the best timing chain that you can use, or is there an alternative???
Old Apr 21, 2008 | 09:28 PM
GMmexican's Avatar
call john from tsp he will hook u up with everything u need, cam install kit, ported oil pump,ls2 timing chain,and gaskets,new arp crank pulley bolt
Old Apr 21, 2008 | 09:31 PM
bigpapi211's Avatar
have fun trying to get it to run and not stall when stopping. id say get it trailored save yourself the headache.
