Ported afr225's.. too big for 346 cubes?
This is just stupid.
Read what I wrote, you dumb ****. I said ported stock castings. Which are even advertised as 220 or bigger.
Most cars on this board that have heads have ported 5.3, LS1, LS6, or 6.0 heads with an intake runner in the 220-230 range. They would be better off with a big runner AFR, TrickFlow, or ETP. Price is usually the deciding factor in those cases though. But to say that 225s are for 4.0 and bigger is absolutely retarded and completely untrue.
i also think either an afr 205 , tfs 215 or etp 215 would be a better option on that 3.9" bore. i would flycut and run an .040 gasket and mill accordingly to raise your scr/dcr. if 93 is availably you should be able to easily run 8.5 or alittle more dcr so your scr will probably be well over 11:5.
Your gonna have to get pushrods anyway. The deal with TFS heads are that you cannot run stock rockers and MUST go aftermarket Yella Terra, Harland Sharp etc.. Think another $400 on top of a $2400 set of heads. If money was no object I would go TFS. AFR, ETP, TFS are all great heads though and you can't go wrong with any of them.
just be sure whoever is going to "work" an already serious cylinder head like TFS,AFR or ETP,they sure as hell better know what they are doing.I know i wouldnt let anyone touch any of those heads unless it was the person who originally designed the port himself.TFS 215's are just as good if not a hair better then the AFR 205's,if money is not an issue of coarse.
What size valves? I'm sure they are a 2.055/1.6 Have you thought about valve shrouding in the smaller stock bore? I Would lean towards a 2.02/1.57 205ish head. Just my $.02
FWIW they are 231cc with AFR's valves. That was using extreme pressure lube on the intake face and cc'ing it like a chamber. It doesn't really matter though, they don't move air and are too big over the short turn. Just the cc number by itself tells you average cross section, but not the area at the venturi, short turn, or pushrod restriction.
#32
There are plenty of guy with low compression FI car's making over 700whp with AFR 205's heads, just look around.
#33
suggestion: call Tony and ask him what he thinks. I always wonder why people come here and ask for peoples opinions that may have no idea WTF they are talking about, when they could just as easily take the time to contact the vendor directly and see what they say about it. Tony knows more about these heads than anyone alive and has always made himself available, I know who I would be asking
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#34
I shouldnt even tempt myself with this question and talk of buying heads, bbbbuuuutttttt.... Are ported afr 225's too much for a 346 cubic inch motor, maybe with 62 cc chambers to keep the compression up?. I Plan on having the mods in my sig, plus ported fast 92/ 92 mm tb combo, a UD pulley and possibly a water pump. Any thoughts on this? If im going to do heads i want to make around 475 or a bit more to the wheels....
