Trick Flow 235cc vs. LS7 head
I'm not sure how this post could have been any more apples to apples. If anything it was biased toward the LS7. Same shortblock, bigger rocker ratio, larger ports, the biggest cubic inch to suck up the air, putting better valvesprings on the LS7's so they wouldn't go into float to early, etc. Surprise surprise, the 7's make more top end power than the 235's. Suprise surprise, cathedral ports make killer low end like Sperry intended.
Now for my rant:
Why is anybody trying to shoot holes in it other than entertainments sake? Had TFS wanted to bias the test, they would run a small cam that ran out of steam before the larger LS7's airflow could make a showing. This cam is an average choice for your average 440ci stick guy..remember the guys that aren't happy with "mere" 427's and they want to pump a big horsepower number. Certainly TFS doesn't need advice about cams any more than Tony Mamo or Craig from ET would. They talk to their customers ALL day long and KNOW what their average customer demands of a certain cylinder head model. Had it been a 215cc runner model in the test, their average customer would want something along the lines of a 230@.050 grind.
Why is it that someone can **** talk, but when it comes time to back up they're talk..they say "company X tested it". Buddy, if you ain't company X, what are YOU doin' posting on their behalf?
If you don't agree on the split, I don't see that it's helping the 235's in particular either. New Rule for the forum, unless you know valve opening and closing numbers independently of two cams and know which events affect what from personal experience with different heads, don't post your "opinion". I read these posts all the time and it kills me there are people naive enough to listen to guru so-and-so's kung-fu chop-suey double-secret engine combo #273X. Unfortunatly on any forum, there's a bunch of keyboard engine builders who've never seen an engine dyno in their life reguritating interweb info.
Note to the newbies: Ask this question before you take someones advice: have they ever sold any winning racing engines? How much time have they spent on the dyno sweating and burning their fingers? Actual engine DEVELOPERS don't hand any valuable information out to people who haven't earned it.
I never said to use
Nevermind, take it for what you will.
I did.
Here's my beef. You've taken what could have been a constructive thread (the fact that TFS asked the community for ideas for further testing), then put a defamatory twist on it based on supposition. You could have phrased it like:
"I'd like TFS to retest a small cam like X, it would be interesting to see to see if it picked up the 7's down low and held up high, or would the 235's merely out torqued the fat port LS7's even more bringing the test to an early halt before the 7's could start to perform." Instead, you're pretty much calling out the TFS guys as Liars. Not nice to someone who spend an awful large amount of money to bring us a test.
Then there was the statement about "in a drag race" the LS7's would win. Again, supposition, not even a bit of math to back it up. Pro stock teams pick the rpm spread over top gear (where they spend the most amount of seconds in their 1/4 mile race) to make the most average horsepower. With an expected 130 trap speed of a 650 horse engine, then stack the gear ratio's of a t56 in a calculator, a 7000 rpm shift out of 3rd gear falls to 5400 in 4th and you'll go through the traps at 6500 in 4th. You could go to a 4.10 gear and shift out of third at 7500 and the average span moves 5800 to 7200. The Ls-7's may start coming in close in such a race, but in no way "beating" the 235's automatically. If a guy has an automatic, he's virtually assured to do better with the 235's with anything but a 5500rpm stall converter to crutch the heads.
Again, I wasn't aiming my comment squarely at you, but that's how some of the posts on this thread have come across.
No I am not personally an engine builder. At the risk of some of the he said regurgiting of facts, I count a few of the best people with these engines as not only my freinds, but I have in fact hired them to build my engine. I have spent many, many hours on the phone with them talking theory and going over results. They are not run of the mill hacks. They have World Championships on their resume's. Notice I didn't say track championships. While I have never had the opportunity to put a wrench on these motors, I am fairly mechanically intelligent.
If you notice in my first post, I said that I applaud the effort. And I still do. I have never said anything bad about TFS heads anywhere on here. I still stand by my statement that I believe a true apples to apples test between these two style heads is almost impossible. For a very large portion of people, the tfs heads will get the nod. I apologize for my phrasing.
I am done.
How about a 3200 lb Camaro with a 408 with ETP LS7 heads and a stock LS-7 intake.Check out the following video and the MPH,this is NA and yes the car has a 260-270 cam that doesn't work with Ls-7 heads(LOL)
http://fastlsx.vidiac.com/video/7417...6a016bc787.htm
Ray T
I am done.
That's cool. It's pretty easy to get heated up over nothing and again, my post was not aimed squarely at you. As a manufacturer doing our best to make good stuff, I appreciate the testing these companies bring to us. All too often, there's a lot of fluff and BS in advertising these days and it's nice to see companies that really try to shed light on things like this. -
Lift Value Intake Flow CFM Exhaust Flow CFM
0.100" 65 55
0.200" 144 124
0.300" 229 196
0.400" 287 242
0.500" 323 260
0.600" 340 270
Tests conducted at 28" of water (pressure) with a 4.125" bore flowplate.
CNC-profiled chambers; exhaust with 17/8" pipe.
Thanks
TrickFlow Tech
This goes to TFS, and TFS ONLY, if you guys really want to compare your heads all around against the LS7 heads, you NEED to run both sides of the fence, esp because they're such different heads. Once with a cam better suited for your heads (like you've already done) and one with valve events better suited for the LS7 heads, this way there CAN'T be any one claiming an unfair comparison. And who knows, you may find that your heads out pace the LS7's all around! Wouldn't that be something to test for =D
Best Regards.
Brett
Point I made was the trickflow motor with it's much better torque curve would spank the LS7 combo in this comparison in a drag race.
I assume from your post your were talking about what was posted by trick flow in the very 1st post! The had this on an Engine dyno. Not a wheel dyno
Nothing about wheels in there
