cam timing ?
Old Apr 28, 2008 | 10:05 PM
teddyls1's Avatar
Default cam timing ?
Im wondering where to set my crank sprocket on my adjustable rollmaster chain setup. Building the motor right now it has -2 forged diamond pistons eagle rods stock crank and the block is bored to 3.905. Cam is a Ms4 which is supposed to have a 4deg advance ground in but has not been degreed yet. Valve train is 1.7 hardland rockers, ls7 lifters, chromoly pushrods. I plan on spraying between 100-150 shot in the future. Not sure if i should set the crank to 0 or maybe back 1. Thanks
Old Apr 29, 2008 | 09:04 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
FYI, the MS4 is ground by default with +1º of advance in it. So unless you requested otherwise when you ordered, yours should be +1 as well
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old May 1, 2008 | 04:24 PM
teddyls1's Avatar
Ok I did check and the cam is +1. So with that said what should I set the crank to? Thanks for the help.
Old May 1, 2008 | 09:22 PM
teddyls1's Avatar
Ttt!!
