Sneek Peak Of Prototype PRC Castings INSIDE!!
Old Apr 29, 2008 | 08:01 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Default Sneek Peak Of Prototype PRC Castings INSIDE!!
Guys here's a few pics of the all new Precision Race Components cathedral port cylinder heads. Sorry for there being so few pics, but I'll hold most the pics & specs for when the final version is completed.
We're currently working on several different versions of the heads but past that I can't really give any additional information.
Here's what I can tell you:
.800" thick deck!!
Modified Valve Angles
Better Than Stock p/v on some port configurations!
Multiple Port Options
Multiple Chamber Options
6 Bolt Upgraded!!
356-T6 Aluminum Casting
Designed & Built completely to our specs!
We're currently testing various versions of these cylinder heads on several different applications.
Sorry I can't give any additional information currently.
All I can say is I think you guys will really like the flow/features/pricing of this cylinder head!
*these things are made in America!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Apr 29, 2008 | 11:59 PM
up up up!!!
__________________
Jason
2005 Twin Turbo C6
Old Apr 30, 2008 | 12:55 AM
BOTTLEFED383's Avatar
thats cool but im gonna mad if the price is withing my prc 2.5 heads and they out flow them cuz ive only had them on like 3 weeks and i love their performance
Old Apr 30, 2008 | 08:05 AM
1CAMWNDR's Avatar
OOOOooooh! Very interesting. The choices just keep getting better and more confusing for when I need to upgrade past my Bo White heads one day in the future.
Old Apr 30, 2008 | 02:04 PM
LS1C5Vette's Avatar
How long do you think Jason before they are out? 2 months? 3 months? Ill hold out on getting the new 5.3l R heads for these if they are better
Old Apr 30, 2008 | 02:09 PM
Jon@Texas-Speed's Avatar
July is my bet
Old Apr 30, 2008 | 02:10 PM
user 70810891082's Avatar
To us noobs, explain why these heads are going to be bad ***.
Old Apr 30, 2008 | 02:16 PM
LS1C5Vette's Avatar
+1 ANY info you can get will help, I am looking to get a set of heads from you guys soon, a quick question is will these be better than your new 5.3l R heads?
Old Apr 30, 2008 | 03:46 PM
Jantzer98SS's Avatar
Hmmm aftermarket vs. stock ported GM. All the time and r&d $ to make a head worse than what they have? Isn't it quite obvious?
Old Apr 30, 2008 | 04:50 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
That'a nice thick deck. Are they taller and thicker like the et castings or just thicker all together?
Old Apr 30, 2008 | 05:19 PM
c5_ls1_6spd's Avatar
subscribing
Old Apr 30, 2008 | 11:41 PM
LS1C5Vette's Avatar
What are you talking about, I am asking them to compare these heads to their ported stg 2.5 5.3l R version heads
Old Apr 30, 2008 | 11:51 PM
OWN3D BY MY PROF!
He used logic to defeat your argument before it even began. For some odd reason you still desire to carry it on. ???
Old May 1, 2008 | 03:33 AM
LS1C5Vette's Avatar
Yep its a simple question I am asking TSP not anyone else
Old May 1, 2008 | 03:37 AM
Apollo0526's Avatar
Looks awesome !! What are they modeled in?? Catia?
Old May 1, 2008 | 03:39 AM
Jason clearly stated he wasn't ready to divulge all the specs. Common sense tells me that he can't compare it with the 5.3l head without discussing the flow numbers and test results.
Old May 1, 2008 | 08:52 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
To answer the question earlier, when you port a factory head, you are forced to work within the constraints of how GM designed the head. With an all new cast head, you can start with a 'clean sheet' if you want to call it that, and add material where you want it but with a factory head it's more difficult to do. Like the original post said, they plan to change the valve angle as well, which helps with piston to valve clearance as well as flow characterisitcs.
Old May 1, 2008 | 08:58 AM
Apollo0526's Avatar
+1
+2
Old May 1, 2008 | 09:24 AM
nor-texLS1's Avatar
need anymore test cars?
Old May 1, 2008 | 11:38 AM
Grimes's Avatar
Cant wait to see the results......AND the price!
