SqueeEEeek
Old Aug 5, 2003 | 06:59 AM
swmapfox25's Avatar
Default SqueeEEeek
Hey Guys I just bought my car and it seemed great now (1 month later) I am hearing some major squeeking (I have not been driving the car hard) I know the idler pulley is usually the colprit but it sounds more like it is comming from the bottom of the engine (it is definatly a pulley I think) It is really bad in the morning when the car is cold and it simmers down but does not fully go away. It also seems worse when the air is off. Which is why I dont think it is the idler because my past experiences if you put more pull on the idler it made more noise. My question is could this be the compressor or something to do with the ac? Fixable? Possible cost? tips? Thanks guys for any help
Old Aug 5, 2003 | 07:08 AM
Reckless's Avatar
Super Moderator
Default Re: SqueeEEeek
Squeek I tell you! Squeek!
Could also be the idler for the A/C belt. That is down there pretty low.
Old Aug 5, 2003 | 07:09 AM
swmapfox25's Avatar
possible part number?
Old Aug 5, 2003 | 07:13 AM
Reckless's Avatar
Super Moderator
Not sure about that? Give SDPC a call (banner on right side).
Old Aug 5, 2003 | 07:20 AM
hondakiller's Avatar
id like to know too. i have this problem but im too lazy to fix it. same symptoms too, loud when cold but goes away when the engine gets to temp. it also usually only does it when its been raining out.
Old Aug 8, 2003 | 10:06 PM
swmapfox25's Avatar
OK i started to change it the idler pulley but i dont think it is the right part. I think it is the altenator? Hard to change??
Old Aug 9, 2003 | 04:46 AM
jrp's Avatar
jrp
SN95 Director
same problem with me too. only i noticed it only after my busted radiator hose spewed coolant all over the engine :o. it has gone away and simmered down alot now though so i dont know :dunno:.
i dont think its anything major though, just kinda annoying.
Old Aug 9, 2003 | 05:16 AM
JPJBC's Avatar
get you a length of hose(6-8ft) and have a buddy point it at a possible culprit while you listen to it through the hose... this should help you found out exactly where its coming from...
joe
