Where is TDC #1
Old May 3, 2008 | 12:43 AM
verano29's Avatar
Default Where is TDC #1
I'm torquing down the rockers according to the GM service manual. According to the GM service manual picture TDC #1 is when both dots (the crank and the cam gear) are pointing up (12 o'clock).
It says when #1 is TDC torque exhaust of 1,2,7,8 and intake of 1,3,4,5
Then rotate engine 360 and torque exhaust of 3,4,5,6 and intake of 2,6,7,8
It seems there is some disagreement as to where TDC #1 is, some say its when both dots are facing each other others say its when both dots are at 12 oclock. Which is it?
I followed the manual and did the procedure when both dots were pointing up (12 oclock) at it certainly seemed that the torquing sequence was correct (that all rockers were off of lobe lift).
Check this thread for the GM Service manual description:
http://forums.corvetteforum.com/show....php?t=1921903
Old May 3, 2008 | 01:09 AM
BatmobileSS's Avatar
TDC for number one (first one on drivers side) is the dots facing eachother. Dot on the cam gear straight down and dot and the crank straight up.
Old May 3, 2008 | 01:16 AM
ChrisH821's Avatar
Well they are both TDC... the crank spins twice for every one revolution of the camshaft, thus the #1 piston is at TDC two times (dot to dot and both dots up). I think the spinning 360* part is so you arent torquing down against the valvesprings causing false numbers.
Old May 3, 2008 | 01:37 AM
Last C5's Avatar
Both positions are TDC, but only the position with both dots at 12 o'clock is TDC of the compression stroke which is what you want for valve work.
Old May 3, 2008 | 04:22 AM
DaddySS's Avatar
They are telling you to torque both intake and exhaust for #1 so that should be compression TDC. Take the plug out, put your finger over the hole and turn it over until you feel the compression, that should be dot to dot TDC.
Old May 3, 2008 | 07:24 AM
verano29's Avatar
Yes I want TDC of the compression stroke. I can check that easy enough I guess. If TDC of the compression stroke isn't when both dots are at 12oclock (as opposed to both dots facing each other) I'm going to be sending GM a bill for wasting my time for thier poor quality control on thier products (the GM service manual being one of thier products).
Old May 3, 2008 | 08:13 AM
Randy WS6's Avatar
Compression stroke on #1 is at 12 o'clock and compression stroke on #6 is dot to dot ...
Old May 3, 2008 | 08:19 AM
verano29's Avatar
Awesome! Compression stroke TDC is both dots at 12 o'clock...looks like I won't be sending a bill to GM after all!
Old May 3, 2008 | 09:55 AM
69GMC/99LS1's Avatar
I think you better look at that picture again...that shows TDC for #6. Further down in the thread someone else noticed this too.
TDC #1 piston is cam gear mark at 6 oclock, crank gear mark at 12 oclock.
The FBody service manual has the correct photo.
Old May 3, 2008 | 10:17 AM
eallanboggs's Avatar
It's encouraging to see so many people who are willing to tear their engines apart who don't even know basic 4 stroke theory. Maybe encouraging isn't the correct word. Scary is probably a better work.
Old May 3, 2008 | 10:31 AM
KCS's Avatar
KCS
Moderator
The whole point here is to torque down the rockers when both lifters (intake and exhaust) are on the camshaft base circle. Pull the plugs, rotate the engine until neither pushrod moves (just after the intake closes) and there is no more air being pushed out of the spark plug hole. Torque #1. Turn the engine 90* and then torque #8, and continue on through out the firing order turning the crank 90* before moving on to the next set of rockers. This is about the safest way to do it.
Old May 3, 2008 | 11:46 AM
code4's Avatar
Just watch the rockers when they both go down tighten them. You are just trying to get the spring pressure off of them so they torque properly.
Old May 3, 2008 | 08:44 PM
verano29's Avatar
Does anybody have their motor apart (at least the cam/crank gear showing). Can you quick put an end to this and determine if TDC for #1 of compression stroke is when both dots are at 12 o'clock or when they are next to each other (12 o'clock for crank and 6 o'clock for cam). I could have determined it quite easily but since I knew the position of my crank when I began the process I just assumed tdc on compression was when both dots were at 12 o'Clock.
I'm betting that its when both dots are 12'oclock. I say this because following the procedure it sure seemed like the correct lifter was off lobe lift.
Old May 3, 2008 | 08:47 PM
verano29's Avatar
Where's vettenuts, he'll know the answer for sure.
Old May 3, 2008 | 08:55 PM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
With both dots at 12 and 12 its the firing position for cylinder #1 or TDC of compression stroke.
When the dots are together that is the start of the intake stroke.
Old May 3, 2008 | 08:59 PM
verano29's Avatar
If you look at the service manual clip in the link you can see why its so confusing. It shows the two dots at 12 o'clock but the cam dowel would indicate its at 6:00 o'clock. It then goes on to describe the crank key as it would if you were looking at the motor but then describes the cam dowel as "it will be at 10:30 if your looking from the rear of the motor." I bet this nuget of technical writing was part of an off-shore outsourcing project.
Old May 3, 2008 | 09:00 PM
verano29's Avatar
That's what I want to hear....but does that make it correct?
