stock cam and lift question?
Old Aug 5, 2003 | 11:59 AM
2000ws6transam's Avatar
Default stock cam and lift question?
here we go!! i measured the lift on the pushrod side and it came out to be exaust side #1 .295 #3 .300 #5 .295 #7 .250
now could this be a bad lifter or cam lobe on #7?
Old Aug 5, 2003 | 12:22 PM
30thWS6's Avatar
Default Re: stock cam and lift question?
I'd guess something is wrong there, bent pushrod, worn lobe, etc., worth investigating further. Does anyone know the specs on a stock LS1 cam? I've been wondering myself.
Old Aug 5, 2003 | 12:32 PM
all the intake side were .270-.280. i have manley chromoly heat treated pushrods with less than 5k on them i also have REV 1116 dual coil springs stock rockers and lifters
Old Aug 5, 2003 | 04:01 PM
Cal's Avatar
Cal
stock LS1 cam '98-00:
202/210 intake/exhaust degrees duration
.496/.496 inches lift
116 LSA
stock LS1 cam '01-02:
198/197 intake/exhaust degrees duration
.478/.478 inches lift
115 LSA
Old Aug 5, 2003 | 06:14 PM
nuzee's Avatar
lifter bleed-down difference?
Old Aug 6, 2003 | 07:12 AM
i see different specs in a gm high tech book! but those rateings are after the X1.7 then correct?
