anti-seize compound...where to use it?
Old May 3, 2008 | 09:37 AM
verano29's Avatar
Default anti-seize compound...where to use it?
Quick question. Where should I be using the anti-seize compound? Just the sparkplugs or exhaust, intake, etc. etc.
Old May 3, 2008 | 09:54 AM
verano29's Avatar
anybody know where I should be using this shizzle?
Old May 3, 2008 | 10:21 AM
KBG's Avatar
KBG
just plugs
Old May 3, 2008 | 10:24 AM
1_bad_TA's Avatar
on the plugs for sure
Old May 3, 2008 | 10:45 AM
deadmanTA's Avatar
Plugs and I put a very lite amount on the O2's.
Old May 3, 2008 | 11:00 AM
Last C5's Avatar
I use it pretty much anywhere a steel bolt goes into aluminum threads.
Old May 3, 2008 | 11:07 AM
Bill Bowling's Avatar
Plugs and O2's here but could use it in more places.
Bill
Old May 3, 2008 | 11:19 AM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Talking
Another Vancouverite agrees with you....
Old May 3, 2008 | 11:23 AM
KBG's Avatar
KBG
might help to tell us exactly what you are doing.....just a tune up or are you putting a whole motor back together????
Old May 3, 2008 | 01:26 PM
verano29's Avatar
heads, cam, intake, exhaust
Old May 3, 2008 | 03:24 PM
vettenuts's Avatar
O2's require sensor safe and should be applied, its in the GM manual. Spark plugs as well. I have studs for the exhaust, but used ARP Assembly Lube for installation.
Old May 3, 2008 | 03:29 PM
KCS's Avatar
KCS
Moderator
This is pretty much it. Whenever a strong metal like steel threads into a softer metal, like aluminum, you need to use a lube to prevent galling.
Old May 3, 2008 | 08:37 PM
verano29's Avatar
I didn't use anti-sieze compound on my head bolts (TTY). I hope this isn't going to be a problem. The service manual didn't call for it...atleast it wasn't that apparent.
Old May 4, 2008 | 01:28 AM
Grimes's Avatar
no, you don't use it on the head bolts, that would actually interfere with the torque readings you used.
Old May 4, 2008 | 11:26 AM
KCS's Avatar
KCS
Moderator
I'm sure it's fine.
Old May 4, 2008 | 03:16 PM
socmguy's Avatar
Restricted User
^ exactly
Old May 4, 2008 | 10:58 PM
PLucas's Avatar
I use it on almost everything...within reason though...not usually on any engine parts.
Old May 5, 2008 | 06:43 AM
AU N EGL's Avatar
Suspension bushings to keep the noise down
