Trick flow heads and rocker clearance?
Old May 9, 2008 | 08:12 PM
shift123's Avatar
Default Trick flow heads and rocker clearance?
Is there an issue with rocker clearance and the valve covers with trick flow heads? I will be using the Harland Sharp rockers.
Old May 9, 2008 | 09:56 PM
silver01z06's Avatar
as far as i know they did not have any issues when my engine was assembled
Old May 10, 2008 | 06:30 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
I thought the Trick Flows needed Yella terra rockers?
Old May 10, 2008 | 03:29 PM
m8w6r77's Avatar
the trick flow packages at summit come with the harland sharp rockers.
Old May 10, 2008 | 08:29 PM
jermzz's Avatar
but will either cause a problem with stock valve covers is the question.
I dont know. I got the yella terras. havnt put the heads on the motor yet though.
Old May 10, 2008 | 09:04 PM
HEMIETR's Avatar
I had issues with both the HS and YT's. I'm sure it would depend what lift cam you are running as well. I had to grind the **** out of my valve covers to get clearance.
Old May 12, 2008 | 10:17 AM
TrickFlowTech's Avatar
LS1Tech Sponsor
With the valve angles on our heads you should not have a clearance issue.
__________________
Old May 12, 2008 | 05:24 PM
shift123's Avatar
Thank You. I thought I read somewhere on here you needed to run spacers or something like that when using stock valve covers.
Old May 12, 2008 | 05:46 PM
HEMIETR's Avatar
Check to make sure. Don't take their word for it. HS and YT say they will fit under stock covers. Mine and many other did not.
Maybe they are fine with a stock cam.
Old May 12, 2008 | 05:49 PM
Jordan S.'s Avatar
I had to cut the baffles out on on the passenger side for my Yella Terra UT's. I grinded a couple spots on the drivers side just to be safe.
