cam queston
Old May 10, 2008 | 03:07 PM
speedracer2536's Avatar
Default cam queston
im not sure but on the ls1 when u put a cam in and line up the crank and the cam gears dot to dot do you have to have it at top dead center on cyl 1 or does it not matter?
Old May 10, 2008 | 11:18 PM
massls1guy's Avatar
If the crank dot is pointing straight up then cylinder #1 is at TDC. So when the crank and cam gears are 'dot to dot' you are good.
