head gasket
Old May 10, 2008 | 03:08 PM
teddyls1's Avatar
Default head gasket
Need to pull that heads what would be the best way in the car or drop the motor. Just put a cam in and rebuilt the motor and now the right side is leaking. Thanks!
Old May 11, 2008 | 01:18 AM
99blancoSS's Avatar
In the car is no trouble at all
Old May 11, 2008 | 02:56 AM
LS1C5Vette's Avatar
If you have pulled the heads once it should take you no more than 4-5 hrs to pull the one head and replace the gasket, surface prep is the key
