600/600 cam only?
Old May 11, 2008 | 01:32 AM
SSickLS1's Avatar
Default 600/600 cam only?
Just bought a vigilante 3800 for the T/A. It has headers LS6 intake, cold air and 3 inch true duals dumped. Is a 600/600 too big without heads or gears. I dont want gears since mileage is only going to get worse and i dont want it wrapped out all the time. I dont think that heads are a realistic thing anytime soon since thats a whole extra 1200 easy. Know a kid with an A4 GM hot cam + a similar setup and its pretty weak. He pulls bolt on cars by maybe a car in the 1/4 so im thinking i need a little bigger. I want mid 12's on street tires and high 11's on DR's cam only LS6 intake and all. Realistic? Smaller? 589/589? Although its gonna be a DD there will be no hwy use. Driveability need only be medium.
Old May 11, 2008 | 03:32 AM
PREDATOR-Z's Avatar
Why are you judging cam size by lifts. That is just a part of the cam's potential.
I recommend this cam for your goals:
230/230, .612, .592 111+2 LSA
Custom grind Comp cam XFI/XE-R lobes
It has low 11s potential with the right mod combos (cam only)
Old May 11, 2008 | 04:40 AM
Shawn MacAnanny's Avatar
Yeah that cam did make some impressive results.
Old May 11, 2008 | 09:42 AM
TA1364's Avatar
How much et you think would be left on the table by shifting this cam at 6200-6300? If I remember correctly it started to fall off at 6500
Old May 11, 2008 | 11:29 AM
Bad Blu Formula's Avatar
You should be running high 11's with out a cam. I agree with Predator, his cam choice will do you good. Don't go with a cam that has to peak at 6800 rpm to make power either.
Old May 11, 2008 | 11:37 AM
BIG_MIKE2005's Avatar
Are you smokin crack?? I don't know of a sinlge A4 car with his mods even outta the 12's without juice on top. There is NO way he should be in the 11's without a cam unless he is sprayin at least a 150 shot.
Old May 11, 2008 | 04:25 PM
s346k's Avatar
?? a bolt-on a4 car could easily go high 11s without a cam or spray. my 00 3600lb z28 went 12.25 @ 108 with a poor launch and 2-3 nonshift syndrome. the car went 7.69 @ 88 in the 1/8 a couple months before, i'm convinced that would've been my 11 sec pass had i been on a 1/4 mile track. i didn't make it soon enough before the trans gave up.
long tubes, drag radials, ls6 intake, tune.
Old May 11, 2008 | 04:30 PM
I with you man i dont doubt an ls1 can do high 11s bolt on. My bolt on LT1 is trapping 110mph with no traction, a gfx kit, cage and 154k on the stock cam, heads, shortblock.
Old May 11, 2008 | 04:42 PM
NastySSoo's Avatar
To go 12.2s @108 you would need an awesome 60ft. Period!!!
Paul
Old May 11, 2008 | 04:46 PM
rocksws6's Avatar
^ +1 This is true.
Old May 11, 2008 | 04:59 PM
DOUBT IT's Avatar
*Ahem* Put down your crack-pipe. There are PLENTY of A4's in the 11's bolt-ons only. Take a look at the SI list sometime, it might open your eyes.
I plan to be in the 10's on a 100 shot later in the year, without cracking a valve cover.
Old May 11, 2008 | 05:21 PM
NastySSoo's Avatar
Ive seen wilwaxu go 11.5s with stock internals and an a4. He was within a few hundrehs of what my h/c m6 ran! It was humbling! You do have to have the right combo though!!!
Paul
Old May 11, 2008 | 05:31 PM
408trans_am's Avatar
Closed ex-Sponsor Account
Those stock internal cars also have a ton of work into them, such as a lot of weight reduction and most have pretty high dollar parts, built a3'sor a4's big stall, big gears, aftermarket rears. Slicks, ect. To run 11.5's SI you are going to need some serious work thats for sure. Most have tubular k members, full suspension, drag wheels. Well you get the point.
Old May 11, 2008 | 05:34 PM
I have to kind of agree with big mike here, a SI street car with street tires, full weight, stock gears with just minor bolt ons will not have a chance at 11s
Old May 11, 2008 | 05:37 PM
GMmexican's Avatar
Id recommend what Im going for
232/232 .612"/.604" 110LSA +2
Old May 11, 2008 | 06:07 PM
Shawn @ VA Speed's Avatar
our 228 cam has .600 lift.in a cam only 02 ta m6 car,ran high 11's blowing the tires off
Old May 11, 2008 | 06:58 PM
s346k's Avatar
Paul
the car was spinning and went 1.71 60' - i wouldn't call that awesome...went a best of 1.60 on my 7.6 run. nothing special. stock susp. except for lcas, subframes, and no front swaybar. it's not some magical concoction, it was very simple parts on a very simple car. stock wheels, suspension, interior, longblock, etc etc. mid-high 11s should easily be attainable with an old standby 224 cam.
Old May 11, 2008 | 08:09 PM
NastySSoo's Avatar
I wont waste my time with this conversation, I know better! See ya!
Old May 11, 2008 | 08:19 PM
Paint_It_Black's Avatar
Don't be afraid of lift.. my 228/232 cam has a lift of .644 and I drive it almost daily.
Old May 11, 2008 | 10:57 PM
SSickLS1's Avatar
forget what i said
