lost most oil pressure
Old May 11, 2008 | 03:10 AM
Jammer's Avatar
Default lost most oil pressure
408 ci. when cold it was about 40 psi, within minutes recently it was 20 psi.. then 10 psi at idel these past few weeks. fresh oil, didnt replace filter. Made a 130 run and lost all oil pressure at idle now..10 psi at like 2500-3k rpm so I shut her down. I hear a tinking noise..not really a ticking..but uneven rattle. No knock. Not sure where to start but this was one of Jellys APE 408's, which many have had cam bearings fail.. any thoughts on best way to find the culprit.. or just yank and rebuild. Figured Id try and do a filter change 1st, but not many miles on motor (2500) and 3 filters in that time.
BTW, making 700 rw at 12ish lbs on this..twin T-60's.
Old May 11, 2008 | 03:41 AM
99blancoSS's Avatar
shavings in the oil?
Old May 11, 2008 | 09:27 AM
Jammer's Avatar
just did it..so havnt looked... but nothing obvious on dipstick..will pull oil tonight
Old May 12, 2008 | 10:57 PM
Jammer's Avatar
Oil looks pretty good
.. I;m guessing cam bearings, since most of APE's motors had such issues.
Old May 12, 2008 | 10:59 PM
99blancoSS's Avatar
Yeah thats not good
Old May 13, 2008 | 08:50 PM
Urslozum's Avatar
Default cam bearings??????
I was just wondering if you checked to see if that oil pump o-ring was torn....that will definately cause the symtoms you have. Just an idea....
Old May 13, 2008 | 09:52 PM
427's Avatar
427
That does not sound good......
Cut the filter open and look inside, it will tell the story.
Kurt
Old May 14, 2008 | 10:28 AM
Jammer's Avatar
Kurt
I tried to reach you ... you was gone! PM me with new info!
Cutting filter open tomorrow.
Old May 14, 2008 | 10:29 AM
Jammer's Avatar
Not yet bro.. just getting all the accessories/wires/plumbing out of the way still/.
Old May 14, 2008 | 04:13 PM
trans2000am's Avatar
i call up w2w im having some problem (iron 370) pressure is fine on start up but once i put stress on motor starts to drop down to 20psi i have no engine noise changed oil nothing......the guy i talked to said to check oring and to see if they put the shim in my oil pump.
Old May 14, 2008 | 05:00 PM
Jammer's Avatar
I did contact w2w... but my issue was dif... 0 oil pressure at idel. Im still betting cam bearings... will post up in 2 weeks once swap takes place and I dismantle.
