looking to purchase rockers looking for some help
Old May 11, 2008 | 06:12 PM
matman11's Avatar
Default looking to purchase rockers looking for some help
i have a forged 347 w/ a trex, 64cc heads, 90/90 setup and spray.... i want to swap out the stock rockers... anyone here have preferance, i was looking at either the harland sharp or the crane rockers... any comments would help out..
Old May 11, 2008 | 11:42 PM
99blancoSS's Avatar
The YT Ultra lites would be a good suggestion as well.
Old May 12, 2008 | 12:30 AM
99mongooSS's Avatar
Jesel shaft mount. If you are going to do it...do it right.
Old May 12, 2008 | 04:57 AM
vettenuts's Avatar
Last I read on Jesel, they weren't designed for more than stock lift (non-adjustable).
I am running Cranes now and have installed Yella Terra's, both good rockers. Not a big fan of the Harlands, have seen too many have issues.
Old May 12, 2008 | 12:02 PM
heavymetals's Avatar
Check out the Comp Cams #1500 system.
Some work required to make it all fit, but Whoo Hoo!
Old May 12, 2008 | 01:16 PM
SOMbitch's Avatar
X2 I know someone with the new design spinning 7K no problem. Also you may want to consider sending the stockers to HS for their $225 upgrade/rebuild. Prolly what I will do until i get aftermarket heads.
