Heads w/ TREX v2.
Getting back on topic.... Is there anyway around flycutting ??? Im not sure if i wana do that myself and i dont feel like pulling the motor apart to get them done professionally. Because if thats the case i will just have that done to my forged pistons (thinking about spray down the road). The car has arp rod bolts so i feel confident spinning this motor up there. As far as high compression, we will be running 112 octane
I would be nervous on stock rods (if that's what you have) but I know some have done it.
I honestly do like high rpm screamers but the bottom end and valvetrain gets expensive real quick.
2nd 55cc damn the Valves will hit the Crankshaft not just the Pistons
lol
If you dont mind the question by killer deal is it less than $2000 or more??
To fly cut, you pull the heads. There is a tool, that goes on a drill and you insert it into a valve guide hole on another set of heads and put them on the car to cut the vavles. If you are building an engine, just order the right pistons.
You will have to cut quite a bit with 59CC heads & a T-rex. Might not even be safe for the piston, I'm not sure.
I noticed you are going to run a forged shortblock. Probably need -14cc valve relief pistons. Check with whoever is building your engine.
15:1 compression? Race gas only engine. How are you going to accomplish that compression and have valve reliefs for that H/C set up?
