this is what were looking at...
Old May 13, 2008 | 11:19 PM
Gregorya24's Avatar
Default this is what were looking at...
stage 2 5.3 liter patriot heads and a mti g1 cam 228/232 on a 113lsa....i also have full bolts on and the cam is sitting in my room. What kind of power am i looking at with these heads and cam installed? Ive heard 400 to 410rwhp?
Old May 14, 2008 | 01:46 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Depends on if you are A4 or M6, Geared...ect. But since you threw out the lower set of numbers for heads and cam I would assume that you are probably an A4. Assuming that you are using a tad bigger valves I would say 410 is not out of the question at all. If it makes any difference I am an M6 w/ 3.42's making 421rwhp with stock valved 241's with a good hand port and .015 mill running a 244/248 115 cam.
Old May 14, 2008 | 01:14 PM
Gregorya24's Avatar
i also have a m6, i hoping for a little over 430rwhp
Old May 14, 2008 | 02:17 PM
Dragkid1917's Avatar
if your m6 and you DONT hit 410 id say thats a problem. If you have a humongo stall and sharp gears with an A4 i stil think you should put down 410, i meen its an H/C car.
