Low Numbers?
Car has Pacesetters into 2 no name brand high flow cats, 2.5 inch duals out the back with slp loudmouth resonators. Stock ls1 intake, 232/234 .59x .59x camshaft with ported ls6 oil pump, all new wires, ss3600 yank stall, all new fluids working 02 sensors. Here is a picture of the dyno, i think its rather low and to add insult i got blown away by a stock 03 cobra the other night, like he pulled bus lengths. I know my injectors are at 112% cycle at 5800 rpms but would that cause a sad 334 rwtq with such a healthy cam?
All done on a mustang dyno in perfect weather, probably 70 degrees here in DE
PRC 5.3 heads got it to 383/387. Traction in 1st is non-existant with GRCs.
I wouldn't worry about it. A4s with converters don't dyno worth a damn.
A.You're running too rich. Lean it down to 12.9
B. LS6 intake is good for 5 h.p. Big deal.
the cobra had a cai heat exchanger gutted cats and free mods...it was makin around 380rwhp....
has the car been tuned? somthin is wrong...
I say it's a poor tune. Do a compresion test see whats going on. You shouldnt have lost to a stock 03 cobra. Have you taken it to the track yet? run it up to Cecil Friday it's only $10 as long as it doesnt rain.
Are you off a tooth??? Track numbers will tell the true tale. That Cobra could have been running more boost than letting on too. Good luck!!! I know how it is to worry and agonize over this stuff
Do a compression check on the engnie just to be sure.
As others have said the LS1 intake is not helping. A Ls6 or one of the after market intakes with a ported TB will help.
Running the injectors like that probably isn't good either. Especially as I'd expect that cam to PEAK higher in the rpms.
As for the dyno. Well Mustang dyno's are eddy current or load bearing dyno's and will generally offer up lower, yet more realistic numbers than the inertia Dynojet dyno's.
Stalls can also affect output. Do you know what gear the dyno run was performed in? And was the converter locked?
Then there are other issues such as are the figures STD or SAE corrected? STD means they figures are what the engine is making under the current conditions (temp/humidity, etc.). SAE corrected would use algorithms to give a calculated figured for set atmospheric conditions (more comparable).
This then leads to possible errors in using correction factors and also the accuracy of the dyno itself (calibration).
As for the race?
Well are you 100% it was a stock Cobra? Also remembering that a stock Cobra is full capable of trapping 112mph in the 1320. Most stock auto LS1's are nearer 102-105mph. So even modded you may not be that quick in terms of terminal speed, although you're ET may be better.
Just an intake, catback and pulley change on a Terminator will make a huge difference. Yet for many they may still consider it stock.
Also for the racing, what rear gears do you have? And what speed/gear did you race from?
Even with the stall picking the wrong speed with an A4 means you are going to be out of your powerband for roll racing.
Where could i get a compression test done?
