What Duration Cam?
Old May 14, 2008 | 12:02 PM
follet30's Avatar
Talking What Duration Cam?
I have a stock motor LS1 and Im about to put some heads on(RgR heads from speedinc.com).They are milled .30 and have 2.02/1.57 valves with 650 lift dual valve springs.I was wondering what is the biggest or best cam to go with for these heads with out haveing to fly cut.I have all the other goodies so its time now for heads and cam.The guy bought them from showed me a flow chart and there strength is high lift.I am going to use the stock rockers too.
Old May 14, 2008 | 12:27 PM
5_02ls1's Avatar
what are your goals...the bigger valves and milling are gonna limit you some.....figure out what you want and go custom...
Old May 14, 2008 | 12:29 PM
GuitsBoy's Avatar
Its hard to say. Theres no way to calculate the valve events accurately enough to predict piston to valve clearance. Talk to the shop that did your heads and see what theyve used in the past.
Old May 14, 2008 | 02:03 PM
follet30's Avatar
I bought the heads already milled and around where i live there are not that many shops that i trust.I was wanting a cam in the 2300-7000 range, i was wanting the MS3 but i think that it is cutting it real close on hitting.
Old May 14, 2008 | 02:36 PM
follet30's Avatar
Well i want a cam where i can race at the track and drive around.Im not worried about the numbers i just wont to go fast and have a good launch..
Old May 14, 2008 | 02:37 PM
Dragkid1917's Avatar
Humm, you might be able to pull off an MS3, its just a bit bigger than my 233/239.
Old May 15, 2008 | 03:28 AM
1997bird's Avatar
What tranny type do you have (if auto what stall converter)? What is your rear end gears? Weight of car w/driver? What intake/TB do you have? What supporting mods do you have for the engine?
Old May 15, 2008 | 07:28 AM
PREDATOR-Z's Avatar
when using .030 milled heads ad bigger valves, you have to flycut, with any 230+ cam
Old May 15, 2008 | 08:06 AM
follet30's Avatar
Well can i get a 228 with a 600 lift?Will that cam give me what i need.I have a A4 stock with 410gears.Ls6 intake with 80mm tb and LTs.The car is stcok weight and i am 270lbs.
Old May 15, 2008 | 08:12 AM
85Iroc's Avatar
Sure you can get a 228 with 600 lift. Just have Pred-Z or Pat-G spec you out a custom using xfi, lsl or lsk lobes.
Old May 15, 2008 | 09:24 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Honestly your p/v would be terrible with the MS3 camshaft & milled heads. From what I typically see you'll need to stay around a 228R or a 228/232 camshaft based off our rough idea of what kind of clearance you probably have. Here's a link to the custom cam order portion of our site. I think keeping duration near the range we're discussing should be fine, but just give us a call when your ready to order & we can calculate a few things.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old May 15, 2008 | 10:28 AM
follet30's Avatar
ok thanks for the help,I will be sure to give you guys a call when i order.
