what cam?
Old May 15, 2008 | 12:50 AM
vettewannabe's Avatar
Default what cam?
I have a 2002 z28(A4)and am wanting to get a cam. I have a lid, stainless lts, 3" ORY, flowmaster muffler, and a 3" E cutout. I also have a 160 thermostat that i havent put in yet. I am looking for a cam with a nice sounding lope to it. I dont have a stall yet, but i will be looking at that in the near future also. What would be a good cam for my setup? I havent tuned anything yet, so it seems like i lost some low end when i did the headers, ORY, and cutout. I was debating getting a TSP cam package, but im not sure which cam to get.Any suggestions?...
Old May 15, 2008 | 01:02 AM
gpainnt's Avatar
that depends on what you are looking for in your cam. if i where you i would get all my supporting mods first. in you case that means a intake and tb. then do your research on a cam but supporting mods first always
Old May 15, 2008 | 05:24 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I would pick up a converter at the same time. Cam with stock converter may leave you slower in some areas. The dyno will probably suggest otherwise though.
Old May 15, 2008 | 06:04 AM
02BEAST's Avatar
Dam! sounds like my car before my TC and cam. Forget about the thermostat you can just tune it so the fans come on earlier. I had the blowmaster when I put the cutout in I gained 30hp Make sure you get new valve springs,pushrods and LS2 Timing chain you already have the ls6 intake get a ported TB you want alot of air coming in as possible. If you need more info PM me.
Old May 15, 2008 | 08:59 AM
RedRallyeZ's Avatar
if its just a daily driver i would go with a TR230, for that loud lope. That cam is a 111lsa so it will sound great, same as my torquer III, just a little smaller for daily driving. good torque band as well. as someone already siad make sure you get the good valve springs and at least a timing chain, an oil pump isnt a bad idea either.
as for the stall. Yank ss3600. any yank is a good converter, ask anyone on here, including me, but this ones pretty good for street too.
last thing is a tune, i think its a must have after a cam install, especially when a stall is involved. you car will drive better and be ALOT more street friendly.
Old May 15, 2008 | 09:17 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
I've done several 220/220 & 224/224 camshafts with stock verters. I'd hate to see you go anymore camshaft than that without thinking about a verter first. We typically see 35rwhp approx. from these size camshafts.
Here's the link with the single spring!
http://www.texas-speed.com/shop/item...d=174&catid=49
Jason
Texas Speed
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old May 15, 2008 | 09:07 PM
Default thanks
thanks for all the suggestions. right now it will be either a cam kit or a converter. Would it be smarter just to get the converter first? Will i need to get a tune if i just change the stall right now? Is a 3600 stall too high for daily driver? thanks
Old May 15, 2008 | 11:09 PM
SOMbitch's Avatar
I don't mean to be rude but it is not even a valid question. STALL FIRST. The car will push and maybe surge at stoplights and be a dog down low to boot with the stock unit with a decent sized cam in it. I gained a little over .3 from a Yank SS 3600 alone after I kinda learned to launch it on street tires. On DR's some on here have reported .5 gains. Don't believe those on here though who say " my XXX converter drives like stock and I can't tell a difference CAUSE YOU WILL!!! But if you wanna go fast it's worth the slight comprimise in fuel mileage and drivability. Go into the AT section and search. Yank's website also does a good job of explaining the technical aspect of things so it is a good resource for converter info and jargon.
