Need help
Old May 17, 2008 | 10:07 AM
Electron_BLUE's Avatar
Default Need help
I just got a 2002 z06. It is stock except for the borla exhaust. I was looking at pro-chargers, but the LS6 motor has high compression. Would that be a waste of money?
I was also looking at heads and Cam. Would that produce the same power as a Pro-charger.
Both i would love to get but i can not becasue of money reasons. Appreciate your help.
Old May 17, 2008 | 11:24 AM
5.3LJimmy's Avatar
It is possible to put a supercharger on a high compression engine, but it will only handle a small amount of boost. You could get a set of stock LQ9 heads which have the same ports as LS6 heads with a larger combustion chamber to bring compression down without sacrificing flow. Heads and cam can make a similar amount of horsepower, but the supercharger will make way more low end torque.
I would recommend lots of searching to see what kind of results people are getting from supercharging and heads/cam packages. Check out the forced induction section and dyno results sections.
