Weight difference
Old May 17, 2008 | 03:01 PM
LS100CAMSS's Avatar
Default Weight difference
Anyone know the weight difference between the iron and aluminum 6.0L blocks? Is it enough to affect vehicle handling?
Old May 17, 2008 | 03:18 PM
Almostryan3's Avatar
Yes..
Old May 17, 2008 | 04:54 PM
Bird-Of-Prey's Avatar
I believe it's around 80 lb's.
Old May 17, 2008 | 07:20 PM
studderin's Avatar
yes its 90#s
Old May 17, 2008 | 08:30 PM
99blancoSS's Avatar
75#'s, and it does not effect handling that much. The advaatage to the block far out weighs any negatives due to weight. You can also do a few thing to compensate if your that worried about it.
Old May 18, 2008 | 12:04 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
This is a good chart someone posted before that I saved:
Old May 18, 2008 | 03:07 AM
99blancoSS's Avatar
Interesting. My builder tells me when he weighs them it's 75. I like how it says customer perception for disadvantage. You mean soft metal is an advantage ? An aluminum propoganda chart, NICE!
Old May 18, 2008 | 03:14 AM
PREDATOR-Z's Avatar
I weighed mine and it was 92lbs difference, yes there is a difference in handling. I relocated battery to back, and with tubular frame, upper/lower A-arms, I was back to original.
The extra power and strength for big juice shots are appreciated though
 Michael S. Palmer
