Having problems and would like your input.
Old May 20, 2008 | 08:49 AM
WS6HUMMER's Avatar
Default Having problems and would like your input.
I went to the track saturday to run my car on the jug one last time before I start on the front mount turbo install. To make a long story short I had moved the rev limiter up to 7200 through the pressure of someone at the track and taged the rev limiter a couple of times when I missed a gear trying to powershift (I normally dont powershift). Anyway the car started a popping at high rpm, on nitrous and off the nitrous. It slowed down 4mph on the last pass I made on the bottle and it scared me. Its running open Hooker long tube headers right now so as best I can tell there arent any unusual ticks or noises of anykind. It will however try to die at idle every once in a while though.
I have a 224 cam with all the goodies that come with the package from Thunder including comp 918 springs, titanium retainers, & hardened push rods.
So far I have taken both valve covers off and noticed that the PCV valve was blown out of the back of the drivers side valve cover but still attached to the vaccum line. All the rockers appear to be tight, couldnt find any up and down slack. Next I guess I'll pull the rocker arms and start looking for a bent push rod even though I know its pretty unlikely to bend a hardened push rod. If that shows nothing I guess its on to a compression & leak down test.
I appreciate any input and also would like to know if the motor has to be hot for the leak down test
Old May 20, 2008 | 10:20 AM
JoeyGC5's Avatar
f you pull the oil fill capoff when the car is idling does it puff out smoke. How do the plugs look?
Old May 20, 2008 | 10:43 AM
WS6HUMMER's Avatar
I havent checked the plugs yet but thats next, I have the valve covers off already so I'll have to get them back on after the compression & leak down tests & try that If I cant find anything else wrong.
Old May 20, 2008 | 11:34 AM
5_02ls1's Avatar
check the plugs.....................
Old May 20, 2008 | 11:48 AM
WS6HUMMER's Avatar
Yeah thats next on my list. Thanks
Old May 20, 2008 | 05:49 PM
WS6HUMMER's Avatar
OK, have the plugs out. All 8 look good, no signs of pre ignition at all. I guess I'll do a compression test tomorrow and see what I got. How many PSI (range) per cylinder is good for a 56k mile motor that goes to the track about twice a year? Havent used but 3 10 bottles of nitrous since ive had it.
BTW. I did a scan with my HPT & there are no DTC's other than the usual wheel speed sensor DTC I get from running 27's on back and 26's on the front.
Old May 20, 2008 | 08:54 PM
socmguy's Avatar
Restricted User
What were your times?
Old May 20, 2008 | 10:04 PM
WS6HUMMER's Avatar
I made a motor pass & missed a gear trying to powershift, the next run I granny shifted paranoid from the first run,spun off the line & through 1st and ran a 11.41 @ 126.6mph, the 3rd run it started breaking up doing the popping thing & ran a 11.7 @ 122, thats when I got scared. It normally would run 11.80's all day long on just the motor.
Old May 21, 2008 | 09:25 PM
WS6HUMMER's Avatar
OK, did a leak down test and all 8 cylinders were in the green.
(1) 33% (8) 10% (7)15% (2)20% (6)15% (5)17% (4)15% (3)28%
These are in firing order incase you didnt catch it, Is there anything else I can do to make sure everything is 100% OK?
Here's a pic of the leakdown tester I used so you can get an idea of what the "green" is.
