tORQUE SPEC FOR ENGINE MOUNT TO ENGINE BLOCK ?
Old May 20, 2008 | 07:05 PM
BadLtBlu99TA's Avatar
Default tORQUE SPEC FOR ENGINE MOUNT TO ENGINE BLOCK ?
What Are The Torque Specs On The Engine Mount To Engine Block ?
Old May 20, 2008 | 07:14 PM
Is It 37ftlb ?
Old May 20, 2008 | 08:34 PM
johnLs1camaro's Avatar
yes sir you are correct
Old May 20, 2008 | 10:01 PM
Default single motor mount bolt and nut ?
does anyone know what the torque spec is for the single bolt that sides into the insert on the pedistals ?
Old May 21, 2008 | 12:41 AM
RoDan's Avatar
RFT = really farkin tight! I'm wondering this myself...
Old May 21, 2008 | 12:49 AM
chuckyt1's Avatar
I don't have these bolts on my car but, here ya go,
Tighten the engine mount through bolt to 95 Nm (70 ft. lbs.) .
Tighten the engine mount through bolt nut to 10 Nm (89 inch lbs.).
Tighten the engine mount studs the 50 Nm (37 ft. lbs.) .
Tighten the engine mount bracket bolts to 58 Nm (43 ft. lbs.).
Old May 22, 2008 | 06:16 PM
therobman's Avatar
just crank the crap out of it
Old May 22, 2008 | 11:53 PM
Question 70 should be enough then
I put 70 ft lbs on the single long bolt that connect between the motor moutns and the pedistals ..
